I'm looking for the drawings or plans of the Cosworth TJ V10
coaster
16
Re: I'm looking for the drawings or plans of the Cosworth TJ V10
I will put up some 2d screen captures tonight with an edit, work starts in 5 mins.
echedey
echedey
friend let me know when you publish your work
coaster
16
There is a front and side cad image in the f2000 book, as well as photos of the camshaft geartrain (you can count the gearteeth by eye).
Once the tracing is scaled to the official figures the other features become known such as deck height, bore spacing and gear spacing to establish the diametral pitch (now use the geartooth count).
https://iili.io/BxVVt9.jpg
https://iili.io/BxVXne.jpg
https://iili.io/BxVhMu.jpg
https://iili.io/BxVj6b.jpg
https://iili.io/BxVNFj.jpg
https://iili.io/BxVOcx.jpg
https://iili.io/BxVe8Q.jpg
The deck surface shown was a cleaned up construction 106.5 bore pitch i recall.
All the radius were established by stretching the side view of the deck to account for its 45 degree angle.
So you see, its detective work, time consuming and obsessive, add to this the hundreds of googled images you will refer to for filling in the blanks, so its time for you to google tj v10 and obsessively study it.
Brian.G
Brian.G
334
Nice Dwgs!
Brian,
If you think you cant, you wont, If you think you can, you will
coaster
16
Hello Echeday,
This Danish website has a large amount of TJ v10 parts for sale.
https://turbodkshop.dk/shop/1274-f1-del ... ---tj-v10/
Are you goals to build a running scale model?
A plastic printed model?
Life size reproduction?
If its a scale model, i might suggest you build an 'inspired by the TJ' rather than a mini clone.
Availability of parts will drive your design, glow plug thread, brush cutter piston, with these 2 diameters you can choose valve size and position, maybe 1/4 or 1/5 scale?
So much of the original design would be lost, i suggest imagine your own with an eye to original.
echedey
echedey
I don't just want the drawings in d2 to model in solidwork, and then give them to a publisher to make a book with the drawings and have them for life to collect
Brian.G
Brian.G
334
echedey wrote:
05 May 2021, 23:22
You should know I am doing that very soon and will be publishing it, so perhaps that would save you a lot of time :lol:
Brian,
coaster
16
I look forward to your publication Brian, your contribution to these forums are fantastic.
echedey
echedey
Brian more or less when your book will be published on what dates
masz1231
masz1231
Please help size the overall engine length, width and height
Or cylinder diameter
Or the nozzle spacing size
Can measure the actual size of the overall engine
coaster
16
Mate, without any reference material please choose another motor.
All of cosworths kers era V8's were built to a strict set of dimensions set out by the fia.
They had a 98mm bore, 106.5 spacing, the bottom of the motor to centreline is set to 65mm? The timing gears will most likely have a diametral pitch of 8mm or 7.62mm (0.300") which was a pretty standard thing for f1 motors. The TJ and the CA had near identical conrods, there are technical papers in pdf format with technical analysis of many aspects of the CA motor family.
You still can buy parts at memorabilia stores online.
Brians insights of the TJ probably exhausted the last stock of available parts online.
https://www.google.com/url?sa=t&source ... 9YFMMU
Valve sizes, angles, lift, conrod length expressed as percentage.
echedey
echedey
hello if you have patience next year as I understand Brian g will release a book of the tj v10 engine with the drawings so you can model it in 3d.
Terry
Terry
I thought it was the TJ and CK V10 Cosworth engines. I have some engine parts and drawings.
coaster
16
LK and TJ are closely related except they are 72 and 90 degrees.
CK is different generation, earlier, Alonso raced his 1st F1 race with a CK in a Minardi with Tarso Marquez? It is 72 degree.
superflyte
I have a Cosworth VJ V10 that sits behind my desk at work, and the TJ V10 drawings showing Top, side, under, front and rear elevations.
\Where are you based?
Cosworth V10s in everything!
