New rear wing and T-wings for McLaren
Despite knowing that late aerodynamic developments are useless in perspective to 2009, McLaren have brought some interesting changes to Brazil. Most important is the new rear wing, specifically developed for this circuit. At both sides, the rear wing has upward curves, and while that in itself is not very new, the upper plane follows the same curve and extends to the leading edge of the end plates. While this is hard to explain without detailed CFD analyses, the new shape is most likely working in combination with the end plate slits to create a little extra downforce with the lowest possible drag.
Apart from the new rear wing, McLaren's car is also fitted with single element T-wings, designed to meet just the amount of downforce required at Interlagos.
that endplates look like a renault 2005 and 2006 combi. The 2005 rear wing also has that slit bend upwards, i thought it was to allow cleaner airflow out of the first element
