What used to be a barge board...
Just 15 years ago, a barge board was a vertically mounted plate to guide air more fluently around the air intake area. Several teams did not use such a panel as they found it not beneficial. In sharp contrast are today's F1 cars. The F2007 for instance is equipped with a mixture of panels in the barge board area. While preserving the cut edges at the upper side of the main board, smaller turning vanes have been added to improve airflow. Especially remarkable is a small carbon in between two bigger panels. It needs no explanation to understand that nowadays the frontal side pod area is vital for optimum cooling and minimal drag.
I assume the front (smaller) barge board is to clean up the airflow to the \'winglet\' on the main board.
Is that winglet \"upsidedown\"?
