Wet Setup for Malaysia
Post Sat Mar 24, 2012 10:18 pm
hahaha
AlexD0e
Post Sat Mar 24, 2012 10:31 pm
? Not bad for a wet setup to be the fastest on the straights with 312km/h...
How did you figure it out :D?
Ganxxta
Post Sat Mar 24, 2012 11:39 pm
An announcer on Speed speculated that Mercedes had a "wet setup" in because of "visible body roll" or something to that effect.
Whether or not the car looked mechanically soft is debatable or up to a certain amount of interpretation. I didn't pay that much attention in the broadcast. But even presuming that is true and the car is indeed mechanically soft, who is to say that isn't their dry package and that they felt it was the best compromise? In any event it clearly worked pretty well relative to the field.
What would be telling is if there were an appreciable change in attitude control in the Merc cars from how they unloaded and ran in FP1, to their qualifying / race trim.
Grip is a four letter word.
2 is the new #1.
Jersey Tom
127
Post Sat Mar 24, 2012 11:54 pm
hahaha
AlexD0e
Post Sun Mar 25, 2012 12:14 am
TWC Radar of Sepang: http://www.weather.com/weather/map/inte ... a+MYXX0031
Race starts at 1600 local, rain posible at 1700 local. Anyone for a repete of 2009 again? With a 4 hour limit on time?
ESPImperium
27
Post Sun Mar 25, 2012 12:20 am
Jersey Tom wrote:An announcer on Speed speculated that Mercedes had a "wet setup" in because of "visible body roll" or something to that effect.
Yeah i agree, they are definatly going for the best compromise. That F-duct really gave them an advantage in a postion like this. Although i didn't see anything noticable setup differences from the other cars. Although, i'm kind of concerned about Hamilton's setup if the rain falls because he's been off track and had lockups almost all weekend long but there is no doubt he's a great wet weather driver.
AlexD0e
Post Sun Mar 25, 2012 12:23 am
hahaha
AlexD0e
Post Sun Mar 25, 2012 12:27 am
AlexD0e wrote:Although, i'm kind of concerned about Hamilton's setup if the rain falls because he's been off track and had lockups almost all weekend long but there is no doubt he's a great wet weather driver.
Should bear in mind that from what I've seen anyway, Hamilton has historically been one to push his trail braking quite deep. In years previous I recall him locking inside fronts under the brakes with some regularity - but it works for him.
2 is the new #1.
Jersey Tom
127
Post Sun Mar 25, 2012 1:29 am
It should be noted here that the W03 has a very soft set up.
Its a continuation of the philosophy behind the W02 with plenty of roll through corners, even in dry races.
W03 @ Barcelona (dry)
W02 Oz (dry)
More could have been done.
David Purley
JohnsonsEvilTwin
Post Sun Mar 25, 2012 1:53 am
Agree with JET, the Merc is noticeably softer than either the Red Bull or the McLaren and has been since launch.
There are some good examples if you lookup some onboards from Australia, you can see even down the straights there is noticeably more travel in the suspension over imperfections. This also causes the front wing to frequently graze the ground as noticed and wrongly referred to by numerous pundits as evidence of a 'flexi' wing.
Why exactly, is a subject for speculation, perhaps simply a setup choice, what the car responds best to, or maybe a byproduct of their rumoured interlinked suspension?
Chalke
Post Sun Mar 25, 2012 2:04 am
could there be a diffuser related benefit to running at an angle? grasping for straws here
thisisatest
Post Sun Mar 25, 2012 2:20 am
Could be as simple as they believe the Pirelli tires are very sensitive to ride inputs, and have chosen to generally lean more on mechanical than aero grip as a setup philosophy... or in other words that the gain in mechanical offsets the loss of aero.
2 is the new #1.
Jersey Tom
127
Post Sun Mar 25, 2012 2:25 am
thisisatest wrote:could there be a diffuser related benefit to running at an angle? grasping for straws here
Need CFD or Newey at hand to discern that.
David Purley
JohnsonsEvilTwin
Post Sun Mar 25, 2012 11:02 am
Doesn't seem to be a great wet weather set-up if they were running one.
Websta
Post Sun Mar 25, 2012 12:15 pm
As I said...
Ganxxta
Return to General chat
Who is online
Users browsing this forum: Exabot [Bot], Neno and 13 guests
