Wed Apr 11, 2012 10:19 pm
While in a race with someone on my butt, I would downshift 1 more gear so I could brake later and not allow him to out-brake me and gain position. Racing someone is usually a bit slower than lapping in clean air.
But for lap times, in this car, my average speed throughout the whole sector will be better than if I went to the lower gear.
This seems to only work in this car when taking 3rd and 4th gear corners. Being in a higher gear, or short shifting, means that the car will be putting down even power with no wheelspin, since its a higher speed corner and the car does not have enough power to snap the wheels loose in the rear. When in 3rd in the same corner, I have more power and and am higher in the rev range, but I am feathering the throttle instead of keeping in it so the rear doesn't come all the way around. If I do that, I
In lower speed corners, the car has enough guts to rotate the rear in 1st, 2nd, and the 3rd if you break the wheels loose at the beginning of the gear.
The other thing I noticed is that my tires were heating up less, because I was sliding less, and towards the end of the race distance I was running in practice, my tires were in good shape and not starting to slide.
Simply, and F1 car can accelerate almost as fast as it can slow down. In a momentum car, the brakes can slow you down far faster than its ability to accelerate. The brakes become the enemy.
Speed in = speed out.
