RB Traction Control yin yang
Post Reply
SectorOne
Re: RB Traction Control yin yang
Stradivarius wrote:Let's further assume that Rosberg is running 1:55.0, 1:54.5, 1:54.0 1:53.5, 1:53.0, 1:52.5. Maybe he hasn't warmed his tyres properly on the warm-up lap or maybe he has a small flat spot or something like that, but the problem goes away gradually.
GitanesBlondes
26
Stradivarius wrote:
GitanesBlondes wrote:Unfortunately it makes more strategic sense to simply maintain the gap as needed once it becomes obvious no one else has the pace to match it. We all know the tires being what they are, requires teams to figure out the best way to maximize the overall tire life each stint, while still maintaining a pace that doesn't cause them to go backwards. It comes down to simple risk/reward, and the smart play is not to take any unnecessarily stupid risks from a strategic standpoint.
First of all, it is my opinion that it is relevant in this topic to have some idea of the actual speed advantage that Red Bull has, since a very large speed advantage that has come very suddenly is more likely to be the result of some new system or device, as for example traction control. If Red Bull is performing more or less at the same level as usual, I think it is less likely that they are using TC or something else.
I agree that it makes sense to maintain the gap and looking after the tyres. But here I am considering Vettel's first laps while he built the gap. On these laps, Rosberg was much slower, so after 4 laps it looked like Vettel was superior. But then we saw that a laptime below 1:53 wasn't impossible for Rosberg to do, and he got quite close already on lap 4.
Let me just try to illustrate what I mean with an example. Let's assume that Vettel is capable of doing 1:52.5 and improving his laptime by 0.1 s for each lap for the first 6 laps if he doesn't think about tyre life beyond 6 laps. So he can do 1:52.5, 1:52.4, 1:52.3, 1:52.2, 1:52.1 and 1:52.0 on laps 1 to 6. But after 4 laps, he understands that Rosberg is already more than 7 seconds behind, so he doesn't do 1:52.1 on lap 5, he does 1:52.5 instead and keeps a similar pace after that to keep his tyres alive.
So what we observe (in this hypothetical case is then):
Lap 1: Vettel pulls away by 2.5 s
Lap 2: Vettel pulls away by 2.1 s
Lap 3: Vettel pulls away by 1.7 s
Lap 4: Vettel pulls away by 1.3 s
Lap 5: Vettel stops pushing
Lap 6: Rosberg is on the same pace as Vettel
Lap 7 -> : Rosberg and Vettel run on the similar pace and the gap increases with only one second during the next 10 laps. They both make their tyres last for a similar length of the stint.
Would you conclude here that Vettel was generally 2 seconds per lap faster than Rosberg, because he was pulling away with 2 seconds per lap at when he was pushing? Do you think the times prove that Vettel would be capable of going 2 seconds faster than Rosberg all the time?
I would say that Vettel's best lap while he was pushing to the maximum is 1:52.2, which shows his speed. Two laps later, Rosberg was only 0.3 s slower than this lap. Let's say that slightly smaller fuel load and improved track conditions is worth -0.4 s in lap time, but tyres worn for 2 laps more is worth +0.2 s in lap time. In that case, Rosberg has shown that he is capable of running only 0.5 s off Vettel's ultimate pace. Are these numbers unrealistic? Do the lap times usually improve much more than 0.1 s per lap?
Here's the problem stradivarius, without having access to the full data either team has, it becomes akin to throwing darts blindfolded. You're just making various assumptions based on what you want the result to be -- where the result is that Nico Rosberg in the W04 had the same speed as Vettel, but something prevented him from accessing the speed through the first several laps.
"I don't want to make friends with anybody. I don't give a sh*t for fame. I just want to win." -Nelson Piquet
hollus
Just to bring the thread back on topic, I'm going to talk about Saubers and Mercedes ;-)
In Korea we just saw ramp exhausted cars achieve a 1-2-3-4, and Webber's pace was clearly good enough to make it 5.
Hulkenberg in his slippery Sauber spent the whole race racing other cars. If he ever was behind, he could pass easily in any straight, when he was ahead, the cars behind had trouble even getting next to him. Of course low drag helps, but wasn't it a bit reminiscent of Vettel in other races, where even if his top speed was low (Hulkenberg's wans't), nobody could get close to him after a hairpin? Then came the moment what Hamilton passed him in the pit straight, only to get passed again after corner 2... before the DRS zone! Then he eventually complained in the radio that Hulkemberg had "incredible grip". Actually, one could clearly see Hulkenberg accelerate way earlier than anybody else in corner 2, exactly like Vettel in Singapore.
Now, Hulkemberg was actually slow, and making a Trulli train of sorts. So if he had the straight line speed and the acceleration out of corners, it follows that he must have been lacking in braking areas and general cornering, which normally means lower downforce than the cars around. This also fits with DRS'd Hamilton or Alonso barely closing in towards the end of the longest straight. Yet, out of the hairpins, he had the best grip.
It starts looking to me like cars with Ramp exhausts have superior rear axle downforce in very slow sections, while semi-coanda cars probably get their downforce at higher speeds. I'd thus attribute much of the "TC" Vettel has to the ramp exhaust, and probably to the best developed ramp exhaust out there, which shines exactly where true traction control often does. That the car needs to be driven in a certain way around hairpins to take full advantage of this is another story.
Rivals, not enemies.
Gecko
hollus wrote:Then he eventually complained in the radio that Hulkemberg had "incredible grip". Actually, one could clearly see Hulkenberg accelerate way earlier than anybody else in corner 2, exactly like Vettel in Singapore.
Actually, a lot of this was down to Hamilton's style. He sacrificed corner exit by braking later into T1 and turning in earlier. Therefore He was always in Hulkenberg's gearbox at the apex of T1, but was then on throttle much later. At the time it seemed to me like a very silly way to drive, and still does.
fasterthanyou
What about Alonso then? He was unable to get close enough to Hulkenberg as well.
hollus
Both Hamilton and Alonso, repeatedly, were 20-30m behind Hulkenberg approaching the braking area and 40-50m behind after the acceleration zone. Sure, dirty air is a factor, but we are speaking of double the distance at half the speed. Hulkenberg was visibly accelerating earlier. Both Alonso and Hamilton are clever enough to adapt if they thought they had a chance of getting Hulkenberg in the following straight by optimizing corner exit rather than entry, but they didn't! Again, Hulkenberg fully repassed Hamilton from dirty air before the DRS line.
H2H
H2H
This sums up what I wrote earlier very nicely with an excellent example of todays race. Sauber ran with the Spa-wing IIRC, in any case a relative skinny one and still they got excellent traction out of the slow turns. T1 was a great illustration of it. Obviously for us it is impossible to know ho much is down to which design element of the car but the full coanda approach a la Red Bull is the most likely candidate to explain the acceleration out of the corner, especially compared to the Ferrari of Alonso.
Ferrari with it's different exhaust philosophy seems to get less DF out of the slow turns but profited from a less finicky, cleaner design for the overall aero at the rear. No need for tunnels there, which caused big problems for both Sauber and Red Bull. It is likely that Sauber can not extract as much DF with the EBD in early phase of the corner as the Ferrari engine mapping is not tailored to the system as on the Renault side, focusing on Ferrari itself. However once the throttle was fullly on again it allowed the Hulk to put more engine+KERS power down earlier and the we all know that the longer the straight the more important the exit becomes.
An excellent way to increase the control over the traction. Additionally the Pirellis suffered greatly in the fast corners, especially the right front in T11 but it has less troubles at absorbing the energy spikes at the rear by longitudinal accelerations.
shelly
136
I agree with hollus and h2h. Even if there are sevral factors, it seems that bridge exhausts do give a traction advantage to sauber, redbull and lotus
twitter: @armchair_aero
tim
tim
Was there any truth to RB having to make a change to ECU programming? To me the noise sounds like anti-lag obviously not for spooling a turbo in this case, but for giving the EBD more gasses to work with. Programming it in for light throttle would make it within the rules because its not off throttle.
siskue2005
70
The following is an excerpt from Mark Hughes' MPH column in the 28 February edition of Autosport:
Ross Brawn, who said: “Maybe their exhaust solution [regarding rear-bodywork design] was based on the idea that there would be more leeway with the mapping. [The Renault-engined] Red Bull’s and Lotus’s solution is problematic off-throttle, because in off-throttle mode there is less blowing from the exhaust and therefore less downforce contribution by the exhaust, which means that one has to rely more on the Coke bottle [profile of the rear bodywork]. But the Coke bottle on the Red Bull and Lotus is less pronounced because of their ramp behind the tailpipe. Therefore, their solution is inferior at corner entry compared to the solution pioneered by McLaren, and which all the teams except Red Bull and Lotus followed. It’s possible that they wanted to compensate with clever engine mapping.”
The design choice of exhaust layout is essentially whether or not to compromise the extent of the Coke bottle-style cut-in of the rear lower bodywork by partially blocking it with an exhaust-exit ramp that allows you to target the exhaust flow over the downforce- producing components to better effect. You can either have a McLaren-style sharply-defined Coke-bottle section that enhances the speed of the airflow along the flanks and over the brake ducts and diffuser top, but with compromised exhaust-enhanced downforce. Or you can go the Red Bull route and have ideal exhaust positioning at the cost of compromised airflow from the Coke-bottle section. This would be expected to give you superior downforce to the McLaren layout on-throttle but less off-throttle.
http://www.f1technical.net/forum/viewto ... 14829&f=12
According to brawn, RBR solution is great for on throttle and mclaren style for off throttle....just like sauber demonstrated yesterday
So now RBRs cutting cylinder has negated their braking instability, so they are faster on and off throttle now
raymondu999
Yep. Here's the rest of what I posted when I posted said excerpt:
raymondu999 wrote:The following is an excerpt from Mark Hughes' MPH column in the 28 February edition of Autosport:
It pretty much tallies with what I thought. The ramp/tunnel solution provides a more pronounced exhaust effect, as the exhaust is isolated from any possibility of external interference. But of course given the increased obstruction to the path of other airflow there would be more drag thanks to the boundary layers, and also a less powerful effect from all other airflows (other than the exhaust-derived airflow). As I posted early on in another thread: http://www.f1technical.net/forum/viewto ... =6&t=14500
raymondu999 wrote:I think the difference really just stems from there. The Red Bull style, I would think, has a much stronger exhaust effect as the effect is shielded from any other flows, but at the cost of added drag, as obviously there will be additional boundary layers and additional choking issues to contend with.
IMO the reason why more people went McLaren is that it was easier to set up - but at the cost that the exhaust effect would be less, as the exhaust direction will be much more affected by other flows of air.
Regarding helping them regain the coke-bottle efficiency, it's an interesting problem - one that in my opinion Lotus and Red Bull have tackled in completely diverging solutions. The Lotus ramp terminates all the way near the diffuser - I think they're trying to completely scavenge whatever airflow they can into their tunnel, so that it "replaces" their original coke bottle, to help them with off-throttle downforce. The Red Bull, however - has terminated its exhaust ramp earlier. IMO this basically is so that the air can flow more "naturally" around the ramp itself as well. If you looked at the car from an aerial shot, it does look like there is a coke bottle shape forming behind the entire ramp/tunnel on the RB9 - so that when the exhaust gas isn't there, the air goes back into a more natural coke bottle. A "secondary" coke bottle, if you will.
失败者找理由,成功者找方法
dren
226
Tommy Cookers wrote:the KERS machine (motor/generator) has a specialised type of drive that continuously modulates the MG torque
(either torque output ie motoring or torque input (load) ie generating)
the 'demand' signal from the ECU is to give a desired (eg steady) torque although rpm is varying rapidly
the drive always knows the actual rpm, so supplies the MG with appropriate voltage, giving demanded torque despite changing rpm
(necessary because an electrical machine has an inherent opposing 'back emf' voltage that is proportional to machine rpm)
this is fundamentally an internal current-controlled loop equivalent to a torque-controlled system
so in principle the KERS can seamlessly sweep from motoring to generating or vice versa if that's what the ECU wants
any EM in KERS or 2014 has built-in EM rpm feedback or the equivalent, and neither the EM or its drive could work without this
because of this (internal) rpm feedback, wheelspin causes a sudden fall in signal voltage, and in voltage to the EM
so as wheelspin starts the motor torque rapidly starts to fall (by some useful amount, seamlessly even into reverse torque)
(of course, a suitable internal rate of change limit of current/voltage ('slew rate limit') must have been set to achieve this)
for this modulation of torque RCE's 'capacitors, batteries, inductors and a feedback signal' are not needed
RCE instant torque changes (from the machine) are impossible (because of the EM inertia and other factors)
for the torque to be modulated according to wheel load as per RCE some load sensing device and feedback would be needed
this would surely be banned via a protest and ruling ?
so wheelspin (even wheel locking) can be and is deterred using the inherent characteristics of the EM and its drive
(this deterrence however achieved depends fundamentally on the EM capability, so will from 2014 be much greater)
so legal (passive-component) networks as per RCE may be more useful in 2013 than 2014
Could a motor withstand multiple pole slippage? It'd certainly make a loud noise.
Honda!
H2H
H2H
Possibly the most interesting technical bit came after Q3 with Vettel saying: "That's all I had, car is quite poor under braking. Thanks a lot guys for getting the car back"
We know he had no KERS in the finale runs and had to adjust his brakebalance. "KERS has failed, moved brake balance 3 clicks rearwards to compensate." Beside from the reduction of braking power, according to Wurz up to 1.5%, it had the obvious impact on his braking balance. However it also should have to do with the importance of KERS in powering the EBD under breaking.
I wrote that earlier:
KERS obviously has a considerable impact on the behaviour of the car under charging/braking. It is a variable teams have to play with and it allows to modulate the torque output coming out of the engine. I saw it mentioned quite a while ago and at least some teams seem to use it to get away with more exhaust gas for the aero benefit as kinetic energy of the engine gets skimmed of by the recovery system and is transformed electric energy or dumped in thermal one by resistors. So KERS has certainly an influence on the effectivness of the EBD, how much is impossible to say from my chair.
So for teams getting the most out of the EBD KERS might be somewhat more important then for the other ones. If we consider what Scarbs wrote earlier about the high amount of 'dumped' kinetic energy the impact under breaking might be higher then most think. It gets obviously combined with those clever engine and throttle maps with the cylinder cutting.
Just imagine the EBD effect with ERS had the rules not been changed! It is certainly amazing how much downforce some teams have clawed back after two big rule sticks aimed at reducing it's performances effect...
shelly
136
I agree on KERS + mapping helping in traction.
When stricter rules for exhaust came, most thought EBD was gone . today with Coanda EBD is still there.
The new rules will force some more lateral thiniking, but we will see exhausts being used again for downforce.
rgkma
Horner has admitted that their KERs is in the gearbox.
@7.49
http://www.bbc.co.uk/sport/0/formula1/24506767
Post Reply
