Ogami musashi wrote:for what it's worth:
"Peter Wright's "Formula 1 Technology"
Thanks, that´s a really interesting graph!!
It does stop in 2000, but it´s very helpful to make an idea of how perfomance or downforce has been changing
Juzh wrote:SectorOne wrote:I think the graph just wrapped this up very good.
Early 90´s was the hayday in downforce but the peak in the 80´s is higher then it is today.
spain 1993 pole 1:17.809
spain 2000 pole 1:20.974
spain 2006 pole 1:14.648
Can't argue numbers.
Agree, numbers are numbers, they can´t be twisted. I agree there are many factors affecting lap times, but....
Juzh wrote:
1993 - slicks, 3.5 v10, active suspension
2006 - grooved, 2.4 v8
1993 had numerous advantages over 2006, yet is still 3s slower. Also, we're not talking DF numbers in case you forgot. We're talking sheer cornering speeds.
Tires, engine and suspension were better/faster in 93, so even when more factors may apply, these three are three big factors that should make 93 laps faster, but they´re slower and by a good margin (3seconds per lap on a short track!!
). So you don´t need a full analisis to say 2006 downforce was close if not higher than it was in 93, it´s obvious.
Looking at the graph, I think what I read about drivers getting dizzy must be in 1993. That´s the highest downforce we will ever see because humans can´t take anymore (at least witout G-suits and while races last almost 2 hours). Since then it´s a continuous fight between engineers improving perfomance, and FIA limiting them to avoid they go beyond human limits. We will never see huge improvements again because of this, sad but true
Anycase the point of the thread (is F1 becoming too slow?) is proved to be false, it´s not slow by any means, lap times are faster than they have ever been, at least in 2006, and they keep improving 06 lap times, so I´d say F1 has never been so fast. They´ve reached human limits when cornering (depending on the track, but it´s the worst case scenario that put the limit), but they can still improve traction, handling, stability, suspension, next year engine and power, braking.... so even when cornering speed will not improve too much, we still will see more improvements
