/thread.GitanesBlondes wrote:That's what happens when you have no real track limits, and curbs that are friendly to ride.
Track limits are never going to be truly enforced because it has become too subjective.
Totally concur mate =D>It's way to forgiving for a class and sport like F1.
http://www.circuitpaulricard.com/views/ ... sse_en.pdfTim.Wright wrote:Has anyone got a proper source about these supposed "tyre destroying" zones at Paul Ricard because I find it hard to believe that something like that will damage a tyre unless you travel over it with a locked wheel.
Though, I must say, if there is loads of run off then putting a tyre slicer at the exit of every corner would fix track limits problem.
Nothing in there about these zones damaging the tyres. That seems to be an internet myth which has propogated itself from forum to forum.kptaylor wrote:http://www.circuitpaulricard.com/views/ ... sse_en.pdfTim.Wright wrote:Has anyone got a proper source about these supposed "tyre destroying" zones at Paul Ricard because I find it hard to believe that something like that will damage a tyre unless you travel over it with a locked wheel.
Page 12 of the presser has some additional detail.
The fact that the paint damages tires is even on the FIA site. It is just not stated whether it is when locked-up only, or under moderate load.Tim.Wright wrote:Nothing in there about these zones damaging the tyres. That seems to be an internet myth which has propogated itself from forum to forum.kptaylor wrote:Tim.Wright wrote:
High grip surfaces only really work if the car has got its wheels still attached:
https://www.youtube.com/watch?v=UdWheuCT0FY
Les Combes and Pouhon should have been kept as gravel pits. Same with Blanchimont. You will lift if you think your entry angle is even off in the slightest.xDama wrote:/thread.GitanesBlondes wrote:That's what happens when you have no real track limits, and curbs that are friendly to ride.
Grass, gravel, sand, whatever surface that isn't smooth will solve the discussion of track-limits entirely. 2 wheels over the white line should result in a reduction of grip, stability and even safety.
I hate the current state of tracks. If Bruxelles was still a gravel box like a couple of years a go, not 1 car would have gone wide. How many cars have gone wide this weekend? Probably every car. It's a good thing that cars get a chance to recover, but IMO it's not the same like 10-20 years ago. It's way to forgiving for a class and sport like F1.
That link doesn't say anything about damaging tyres. In fact it says that one advantage of this type of runoff is that the service vehicles can easily drive over it. Its abrasive, but that is a long way from damaging a tyre. An ultra abrasive surface will wear a tyre out quickly if you keep running over it, but its not going destroy a tyre unles you lock up over it.Edax wrote: The fact that the paint damages tires is even on the FIA site. It is just not stated whether it is when locked-up only, or under moderate load.
http://www.fiainstitute.com/media-centr ... re-02.aspx
+1GitanesBlondes wrote:When Magnussen ran Alonso off the track at 180 on the Kemmel Straight I wasn't even surprised because when you compete in an environment that has virtually no risk involved, you start engaging in moronic behavior on the track. I try and catch MotoGP as often as I can, but I can't recall seeing the sort of chop blocking, and unsafe maneuvers that are currently on display in F1 these days. Biggest difference is MotoGP still has risk, and doing idiot stuff like that will kill someone.
I tried a quick search for motorbike racing on Paul Ricard and didn't find anything. I'd say the run off is the reason why.NTS wrote:There is another problem with surfaces that shred tires: They might also shred a motorcycle race suit if the rider falls off and goes over it without the bike.
So some kind of paint, line or measurement device and a rule that if hit, cross or trigger it you get an immediate drive through seems the safest option. Maybe less definitive than a gravel trap, but enough of a negative consequence to not run out of bounds if it is avoidable.
Even if it is internet myth, it is not a bad idea. Imagine runoff areas that contain zones of broom swept concrete, and zones that contain the shells of small muscles. The levels of abrasive ness can be somewhat controlled (within the skill of the craft) as the surface is installed. The ability of tires to withstand the surfaces would then depend largely upon the tire composition. The bubble gum tires wouldn't stand a chance.Tim.Wright wrote:That link doesn't say anything about damaging tyres. In fact it says that one advantage of this type of runoff is that the service vehicles can easily drive over it. Its abrasive, but that is a long way from damaging a tyre. An ultra abrasive surface will wear a tyre out quickly if you keep running over it, but its not going destroy a tyre unles you lock up over it.Edax wrote: The fact that the paint damages tires is even on the FIA site. It is just not stated whether it is when locked-up only, or under moderate load.
In fact even that's debbatable - see 1:09
https://www.youtube.com/watch?v=Toosc2WUrFA
I think we can consider this tyre "destroying nature" of the Paul Ricard run-off nothing but an internet myth...
