I often hear that its been a while since every team has at its disposal the data from their rivals.
Can we get it?
How are you gonna get to the data which is not streamed to the f1 app? Or do you mean just the F1 app itself?Tim.Wright wrote:At a guess I'd say its part of the live feed monitored by FIA/FOM for fuel flow, yellow flag compliance, timing etc so unless you are physically plugged into the track network or have the credentials to connect via VPN it won't be an easy task.
I'm sure it's only a matter of time before someone hacks the F1 live timing app to retrieve some of this information from the races..
Refresh rate on speed measurements was actually pretty good last year (when it didn't lag). Could be some interpolation involved though to mask potentially low polling rate, but that is speculation.Tim.Wright wrote:Obviously you can't get what isn't there but the fact that it includes a live track map means the data sent might be useful to pull out some speed measurements. Though Id guess the refresh rate is probably too slow for it to be super useful
