RB claims Mercedes uses forbidden oil-mix
Drewd11
Drewd11
Re: RB claims Mercedes uses forbidden oil-mix
sosic2121 wrote:
SiLo wrote:I believe the current theory is they are letting oil seep up through the piston rings. Although surely this wouldn't be a great seal for the piston and you could get a huge pressure increase in the crank case if the seal isn't good enough?
If they were doing it that way, there would be no way of controlling it.
But accusation is that they can make huge power during qualifying.
Could there be an additive in oil which evaporate, and goes through breather pipes into the engine?
Note that the oil is also used to lubricate valves as noted in another thread. I think this would be an easier way to induce oil vaporization with the boost pressures .
void
I think it's oil used to lubricate Mercedes turbo before engine start.
