Rake comparison RB/Merc/Ferrari
Post Reply
F1NAC
163
If the similar topic is somewhere feel free to delete this
Re: Rake comparison RB/Merc/Ferrari
nice comparison, but i think the image is off. you need to take into account the part where the lower part of the rear wheels and front wheels hit the asphalt and use that as the 'horizon' or 'base line'.
maybe my eyes are decieving me, but the lowest line on all 3 comparisons are quite below the front wheel, despite bing level with the rear wheel.
mertol
Braking, accelerating and downforce would influence that. Ideally you should use a picture when stationary.
marmer
also will be affected by the curb potentially
NathanOlder
I know the Mercedes has a longer wheelbase but thats taking the pi$$ lol
GoLandoGo
Lewis v2.0
King George has arrived.
Jolle
mertol wrote:
19 Sep 2017, 15:17
It's variable and that is the whole "thing' how you the teams use it and how it should be compared. Stationary rake doesn't matter, you have no downforce.... Especially the rear suspension plays a trick here, to have max downforce (so max rake) in slower and medium corners, and low drag at high speed straights. It's also one of the tradeoffs between downforce and mechanical grip, for what purpose do you setup your rear suspension? If you go ultra soft, the grip out of slow corners is good, but the rake is less stable and might dip too much at medium to high corners, the rear too stiff and you won't find the grip out of slow corners but you have a pretty steady rake at speed.
GPR-A duplicate2
64
Jolle wrote:
22 Sep 2017, 11:36
mertol wrote:
19 Sep 2017, 15:17
Just to add to the highlight above, you do not want to have too much of rake, which causes flow seperation and you lose downforce. It's always a critical balance of how much rake you want. Which depends upon how you energize the flow from the front of the car. In essence, a lot of your front philosophy makes an impact on how the airflow is going downstream.
CBeck113
51
GPR-A wrote:
22 Sep 2017, 12:34
Jolle wrote:
22 Sep 2017, 11:36
mertol wrote:
19 Sep 2017, 15:17
Very good point, this is the reason why most higher rake cars also have a soft suspension on the rear axle - as the downforce grows with the speed of the car, it lowers itself, reducing the rake, and avoiding this tear-off while reducing drag in the process.
Dazed1
Found elsewhere:
mertol
They use rake to get the front wing lower to the ground. The diffuser is actually too high and they use vortices to help seal its sides off.
Jolle wrote:
22 Sep 2017, 11:36
mertol wrote:
19 Sep 2017, 15:17
It's not variable when stationary that's the whole point. Comparing them in motion will always be apples to oranges.
Post Reply
