Testing
allan
speaking of which, (testing), i wanna ask a question regarding the toyota tf-107:
how the hell does it steer?
http://www.autosport.com/gallery/pictur ... 1097H62P-2
joseff
Are you saying it's too wavy to contain a steering arm? I don't think so. You can definitely trace a straight line through the middle.
allan
joseff wrote:Are you saying it's too wavy to contain a steering arm?
ya exactly... the upper wishbone is just too wavy.. u might be right as it can have a trace of a straight line, but it's just hard to imagine :?
johny
Contact:
for me it's just the same, it doesn't matter the shape
3KGT
What is the advantage of having the upper A-arm shaped like that? Is it for better aerodynamics or for the actual suspension?
Tp
Tp
3KGT wrote:What is the advantage of having the upper A-arm shaped like that? Is it for better aerodynamics or for the actual suspension?
If I was to have a guess it would be to reduce load on the upper wishbone, by reducing the angle between it and the hub, while also improving suspension geometry.
