Yes, that is how I THOUGHT it was, but reading the technical regulations it doesn't specify at all wether it is a maximum or an average flow rate. Hence it can be interpreted as being both.R_Redding wrote:My understanding is that 100kg/hr is a maximum flow rate , equating to a flow rate values of 27.7 grams/second or 13.83g/0.5sec etc...
The "must not exceed" implies that it's a maximum. If you average 100kg/h, by exceeding 100kg/h at some times then you have... well... exceeded 100kg/h.Maxion wrote:Yes, that is how I THOUGHT it was, but reading the technical regulations it doesn't specify at all wether it is a maximum or an average flow rate. Hence it can be interpreted as being both.R_Redding wrote:My understanding is that 100kg/hr is a maximum flow rate , equating to a flow rate values of 27.7 grams/second or 13.83g/0.5sec etc...
Right, but it's stated as a flow rate of kg per hour which would imply a measuring period of one hour. Hence, you'd be complying to the rules if you had an average flow rate of 100kg over 60 minutes.beelsebob wrote:The "must not exceed" implies that it's a maximum. If you average 100kg/h, by exceeding 100kg/h at some times then you have... well... exceeded 100kg/h.Maxion wrote:Yes, that is how I THOUGHT it was, but reading the technical regulations it doesn't specify at all wether it is a maximum or an average flow rate. Hence it can be interpreted as being both.R_Redding wrote:My understanding is that 100kg/hr is a maximum flow rate , equating to a flow rate values of 27.7 grams/second or 13.83g/0.5sec etc...
Why does that imply a measuring period of an hour?Maxion wrote:Right, but it's stated as a flow rate of kg per hour which would imply a measuring period of one hour. Hence, you'd be complying to the rules if you had an average flow rate of 100kg over 60 minutes.
You understand correctly.Xwang wrote:if I have understood correctly there is a Fia standard omologated fuel flow meter on board, is it correct?
ohhh..... is it possible/allowed to make specific shape of the hole, thus could generate desired airflow ?RicME85 wrote:They are on all cars, they are mandated.
Fixing points + FIA measuring points iirc
