Engine freeze - public baseline
Post Mon Aug 11, 2008 9:33 pm
Belatti wrote:It has been disscused in several threads that there are ways to improve engine performance, despite the frozen rule. I see your point axle, but if FIA does what you say, F1 will transform in GP2 (BTW, it already if you ask my opinion).
The problem here is that none of these 2 rules are OK for the sports, the engineers, the majority of racing fans and the drivers. No engine freeze, no equal power/public baseline.
At the end of the day I always end thinking that manufacturers (who started coming in the early 90´s when the great group C was killed by rules -Bernie suspected here) ruined F1. I would love to see them returning as engine suppliers only, let them specialize in building roofed road cars, let art be made by craftsmen!
Belgatti, you speak the truth!
Unfortunately the only way to get big car comps out of F1 is to revive group C.
And that is not a half bad idea ;)
All these regulations are what has made the sport so insanely expensive, as each team had to reach for that last 0.01% of a performance increase instead of betting on something else. Even if that costs them their kidney.
The only way to close a stupid question is to give a smart answer
woohoo
Post Sun Aug 24, 2008 3:52 pm
It is ironic that in making changes to improve reliability, Ferrari appear to have introduced unreliability. STR do not seem to have any reliability problems though do they? :wink:
Williams and proud of it.
pgj
Post Sun Aug 24, 2008 3:55 pm
pgj wrote:It is ironic that in making changes to improve reliability, Ferrari appear to have introduced unreliability. STR do not seem to have any reliability problems though do they? :wink:
They did in Melbourne.
MattF1
Post Sun Aug 24, 2008 5:56 pm
Ferrari is catching heat for illegally modifying their engine (but then they are the team so many love to hate)!
Speed TV's announcers at Valencia frequently referred to the belief in pit row that McLaren/Mercedes have a 25 HP advatage over their nearest competitor . . .
Any thoughts? (Yes, the fastest cars today were running Ferrari engines, but top speed is greatly influenced by aero.)
donskar
Post Sun Aug 24, 2008 7:10 pm
donskar wrote:Ferrari is catching heat for illegally modifying their engine (but then they are the team so many love to hate)!
*IF* the Mercedes engine is the most powerful that says a lot about McLaren aero...ie they are having to sacrifice a huge amount of speed to increase downforce, and yet still not able to match Ferrari. And again IF that is true then I would point the finger at the suspension kinematics. The reason they work the tyres so hard, the reason they'd need extra DF over the competitors...
- Axle
axle
Post Mon Aug 25, 2008 8:27 pm
zac510 wrote:They whinged for years about the costs, threatened a breakaway and asked flat out for rule changes like this. They got them.
If they don't like it they can take their bat/ball and go home. Plenty more privateers that would like the place of a greedy manufacturer.
No this is untrue. Max unilaterally introduced the freeze upon the teams shortly after he made them foot the expense of going to the V8s. The teams didn't want the V8s and they didn't want the freeze.
This Marxist egalitarian freeze is 100% antithetical to the spirit of F1 and Max should be run out of town for it, not for his N@z! hookers. Supposedly it will be with us for ten years. Well it seems that with Renault rumbling and Toyota also there is no chance of that. Hopefully all this nonsense will be over next year when Max leaves.
Not only is the freeze bogus but the V8 rules are as well. V-angle spec'd at 90 degrees, bore centers spec'd, cam locations spec'd, CG spec'd, alloys spec'd, RPM spec'd, ECU spec'd, number of cylinders spec'd etc. etc. All this is bogus and against the spirit of F1.
I believe that the process for a manufacturer to apply for an engine component design change "for reliability" involves not only the FIA approving the change but also their fellow competitors approving the change. This article makes it clear that all the other teams know what modifications their peers are applying for and why. The other teams can also say no to the request.
All this was foisted upon the teams against Concorde by Max abusing the "safety clause" to impose these regs. What does any of this have to do with safety? And where in Concorde is Max appointed King of budgets? If Ferrari want to spend ten trillion Euros chasing the title, then that is their business. If Honda says that is too much then they can do it for less or leave. If everyone left but Ferrari the cache and elan of the F1 title would suffer because we would essentially be reduced to a 20 car grid of all Ferrari powered cars in a kit car class. Teams will place a value upon the title and then act accordingly. It is good that they place a high value upon it. This is freedom and economics and technological development all aligning. It should be free to act upon whatever course it determines. If team "A" sees great value in a rotary engine development, and team "B" wants a thirsty V12 that accelerates like a dragster but is a turd in the bends, and team "C" wants a slower nimble light weight fuel-sipping V6 that corners like it is on rails and team "D" wants to develop a true CVT while team "E" wants to develop a 4WS AWD electro-motive racer with full regenerative potential then they all should be permitted to do so. And the driver's weight plus the ballast should be around 85 Kg so that heavier drivers aren't penalized. All driver ballast should be placed directly behind the driver seat at around 280mm above the floor to mimic the driver CG. After that there should be no more ballast allowed so the cars are designed to be light weight and well balanced apart from the crutch of ballast as it is used today. Let F1 be F1, not another spec racer series. With rules like this the manufacturers would also gain certain marketing value as brand "B" will be regarded as dragster quick while brand "C" will be regarded as a slalom-meister, brand "D" will be regarded as the handling AWD car, brand "A" will be the rotary king etc. Each approach will be esteemed by its philosophical adherents out in the public.
Death to Max's Marxist egalitarian spec racer notions!
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
gcdugas
Post Mon Aug 25, 2008 11:01 pm
Great post gcdugas.
I agree totally..but we know it will never happen..
The world is going to blow up don't you know?
IMPERATOR REX ANGLORUM
CMSMJ1
Post Tue Aug 26, 2008 2:51 pm
Maybe, but we have had another Ferrari engine take an early lunch this weekend.
pgj
Previous
Return to General chat
Who is online
Users browsing this forum: Yandex [Bot] and 6 guests
