"If I wanted to be a smart-arse, I'd have devised a system so that the light goes green to release the driver at the same time as the coupling hose comes off the car."
Bernie makes a good call...
R
axle wrote:Think about it, it takes very little effort to press a button, but to raise a lollipop needs force - you can't accidentally lift it and release the driver but you can accidentally press a button with a twitch of your finger.
Ian P. wrote:I would be all for limiting the number of mechanics working an F1 refueling or tire stop. We would see some innovation from the teams and some interesting developments.
Saribro wrote:nae wrote:oh and as for the ferrari system 2 fails resulting in penalties in 3 races is not realy the pinnacle of engineering now, whats that 6 or 9 uses and 3 fails in total
Convenient to forget the rest of the season.
nae wrote:and as for the NASCAR thing is that not due to them using the invisible flamed
methanol that they restricted the crew numbers?
Rob W wrote:Bernie's take on the situation.."If I wanted to be a smart-arse, I'd have devised a system so that the light goes green to release the driver at the same time as the coupling hose comes off the car."
Bernie makes a good call...![]()
R
guy_smiley wrote:i could be wrong, but i think the system does activate the light when the coupling comes off the car, but for reasons like traffic, there is also this overriding button that a mechanic presses/releases. now, this is speculation, but for instance kimis problem, the light would have gone green as soon as the hose was out, but he left early: his human error. and in massas case, there was so much going on in the pit lane that the mechanic pressed/released the button prematurely thus turning the light green: the mechanics human error. i think if we go back and watch aaalllll the races in which it worked perfectly 4 or 6 times each race, we'd find that it does go green as soon as the hose comes out...
nae wrote:good theory
except that massa was released into the path of another car
and then got a penalty for it
Users browsing this forum: Ahrefs [Bot], CCBot [Bot] and 5 guests
