2009 January Winter Testing
Post Wed Jan 21, 2009 11:37 am
FM2009 wrote: The wake being significantly higher wouldn't affect an F1 car since an F1 car following isn't that high....
Well, but it's still completely covered by the wake.
Actually the density could be quite deceiving here. Looking at the time sheets the STR went a lot faster the entire day. Could well be it is the only car running flat out there.
D'Leh
Post Wed Jan 21, 2009 12:13 pm
I think that's down to the tyres - with slicks, the cars were supposed to be more or less equal compared to 2008 laptimes - but without them, on the same rain-tyres as the 2008 cars, they're probably quite a bit slower, owing to the reduced downforce.
Metar
Post Wed Jan 21, 2009 12:14 pm
chasefreak wrote:
What are the extra linkages at the front suspension for?
this is something really interesting .. will have to look out and see how much they have developed the front suspension.
The supposedly extra linkage is the steering arm which is not anymore positioned ahead of the front upper wishbone. Honda also had this in 2006.
I think McLaren have found it necessary to de-couple them because they have moved the wishbones themselves more to the back. If you'd look from the top, you will see that the wishbones do not connect to the wheel on its vertical centre line, but more in the back. Either this position is correct for in the upright, or McLaren have designed a front suspension where the wheels do not turn around their axis - which is a very interesting, though weird thought.
Anyway, because of that position and because of the limitation of surface of suspension components seen from above, McLaren probably had no other choice than de-couple them, providing the extra advantages that the steering system could be positioned lower into the tub.
Tomba
Post Wed Jan 21, 2009 12:27 pm
Toyota have lost their first test engine of the 4 allowed this year as Timo Glocks engine has detonated and caught fire...
meves
Already one block gone for Toyota.
Three engines left for the whole year. At this rate, it will be hard.
Btw, I understand the rules about the eight race engines, but what is the sanction for exeeding the four test engines restriction?
vyselegend
Post Wed Jan 21, 2009 12:33 pm
Does anyone know why McLaren are running a 2008 spec rear wing on their 2009 MP4-24?
**EDIT** ignore this.
Keir
The front suspension looks very messy with a jumble of arms.
Shaddock
Post Wed Jan 21, 2009 12:34 pm
Can't they repair the block? It's a testing-engine after all, it doesn't have to be as powerful as the race-day engines...
Metar
Post Wed Jan 21, 2009 12:36 pm
Metar wrote:Can't they repair the block? It's a testing-engine after all, it doesn't have to be as powerful as the race-day engines...
It depends if there is a piston sticking out of the side of it :lol:
Shaddock
Post Wed Jan 21, 2009 3:43 pm
Are they actually forbidden to shroud the suspension now then? What's the rules regarding them.
Agerasia
Post Wed Jan 21, 2009 4:18 pm
Agerasia wrote:Are they actually forbidden to shroud the suspension now then? What's the rules regarding them.
You would think that since they work in tension/compression with no bending, that it would be quite easy to shroud them all the way out to the upright... But since any shroud would be larger than the suspension it is shrouding, and heavier overall, there may be no benefit.
Conceptual
Post Wed Jan 21, 2009 5:03 pm
vyselegend wrote:Image
Even the teams are unsure...
http://www.autosport.com/news/report.php/id/72845
but if they run out of test engines I think they dont test anymore, not a huge deal since in season testing is effectively banned.
I hope that if they run out of the 8 race engines that they are penalized for every race after that(on a new engine after that)... otherwise teams could easily flout the rules to add a ninth(or more) race block. Honestly the FIA really dropped the ball on this years engine 3? 4? race rule... since they extended the engine life rule they should have got rid of the RPM limit and let the teams pace themselves... that would have really made the show more exciting... I loved seeing Massa's engine blow up on the last lap, but it wasnt the same becuz it wasnt becuase Ferrari overused it.
Article 28.4a states: "Each driver may use no more than eight engines during a championship season. Should a driver use more than eight engines he will drop ten places on the starting grid at any event during which an extra engine is used.
So it looks like whatever driver that was in that car is down to 7 more bloks b4 he gets pointed to the rear of the grid.
ISLAMATRON
Post Wed Jan 21, 2009 5:26 pm
Actually... Does winter-testing count as part of the restrictions? I would've thought the 4 testing-engines counts only for Fridays?
Metar
Post Wed Jan 21, 2009 5:28 pm
Yeah,but the season has not started yet so I am not sure this counts toward their allocated 8 engines (or 4 or whatever)
Long experience has taught me this about the status of mankind with regards to matters requiring thought. The less people know and understand about them, the more positively they attempt to argue concerning them; while on the other hand, to know and understand a multitude of things renders men cautious in passing judgement upon anything new. - Galileo..
The noblest of dogs is the hot dog. It feeds the hand that bites it.
mcdenife
Post Wed Jan 21, 2009 5:33 pm
mcdenife wrote:Yeah,but the season has not started yet so I am not sure this counts toward their allocated 8 engines (or 4 or whatever)
Exactly why I asked - after all, most of the restrictions that are usually in place don't count for winter-testing...
Metar
PreviousNext
Return to General chat
Who is online
Users browsing this forum: ajinomoto, CCBot [Bot], Google [Bot] and 4 guests
