F1_eng wrote:Marcush, Rubens was on pole in Brazil and a 3-4 finish for the team in Abu Dhabi.
Someone mentioned in another Mercedes thread, they didn't know that ballast moved around the car during the season. Who ever this was, really shouldn't be voicing their oppinion too loud as they clearly don't know much about F1 racing. Not only does it move around for different races, it moves regularly between runs during practice.
Tyre stiffness is massive, at the most basic level it changes the frequency and the spring/daming characteristics of the installed system. If you assume initially that you are going to get 'X' ammount of damping from your tyre and you don't, this has to be compensated for but at a slightly different location. You can change the spring/damper settings which only relate to the sprung parts of the car, the damping of the un-sprung sections are as the tyre, which is stiffer than expected.
This is barely touching the surface at the most fundamental level.
There are lots of reasons why teams/cars/drives can struggle and it sad, how some people get a pleasure in talking teams and drivers down. F1 teams and staff don't claim anything except to try and design the best car possible in their situation, sometimes issues arise which need to be sorted as best as possible. I have never heard anyone who is working in F1 have a go so the cause is certainly envy. Not being able to make the grade or not working hard enough in school.
How do you come to the conclusion that the proposed wheel movement moves balance 0.5%? In your views, how do you think this affects the front and rear tyres and in what way will it benefit the set-up?
well at least i inspired you to respond..
I apologise for being unfair towards Brawns 2009 second half season and giving the
impression of devaluing the efforts of the team per se with my words.
In fact I ´m well aware that things are NOT as simple as I would be able to outline ..of course they are not.But it was Mr.Brawn who basically chose to reduce the problem to a weight distribution issue.
So my thought was : if the 2 inches wheelbase change would be what is going to happen ,then this would represent something like a 1.5% change in wheelbase.From my point of view moving the front wheels could never ever move the CG those 1.5%
so it has to be something in between and so i simply estimated half of a percent.
With reference to the other comments and something DaveW.pointed out somewhere else ,the question is if it really is less static you would need if the fronts have come ot stiffer than Brawn hat wanted them and just why the car would overwork the tyres if there was too much springrate in the fronts..either I´m drawing false conclusions from what has been published - or something does not really add up.
especially if you consider that 620kg/100 x1.5 is not even 5 kilos of weight per wheel we are talking here for the increase of wheelbase ..not a huge number when we consider the downforce playing its part.
