DRS in Monza/New top speed records?/Best place to sit
Post Reply
radosav
Re: DRS in Monza/New top speed records?/Best place to sit
Here is Ricciardo's 360 km/h.
[youtube]http://www.youtube.com/watch?v=BR8kkwJ2d7M[/youtube]
McMrocks
32
SectorOne wrote:Just continue to develop the ERS system. KERS went from 80 to 160 in four seasons it ran so double it again in another four-five years
320 electric horses plus some from the ERS-H for good measure.
Land driven rockets basically.
Funny is that most of the kinetic energy is still wasted. The front breakes have to "destroy"(convert kinetic to thermal energy) more kinetic energy than the rear brakes. Having said that, 320bhp aren't a THAT outrageously high amount. But it is only achievable if the teams are allowed to recovery energy from the front wheels too.
But, why not?
SectorOne
Yea harvesting from the front brakes could be an interesting thing to do as well, downsizing the front brakes in the process.
Doesn´t one of the big three supercars (i.e. P1, LaFerrari and 918) harvest energy from the front wheels?
What exactly needs to change to up the electrical power? Bigger cables, bigger battery and front end harvesting?
NTS
NTS
What would also be an interesting engineering challenge is to not allow front harvesting but to upgrade to 320 hp MGU-K and higher energy store limit anyway. That means they have to find more power from the MGU-H or decide on a worse brake balance (interesting to watch, you can use rear brakes only but it requires braking a lot earlier and carries the risk of losing the rear on entry which means lots of sliding). Up to the teams to find the optimum which could get you a better time because you get more power in an undrivable machine or less power in an easier to drive car.
It also allows a driver to out brake somebody by sacrificing some ERS charging which could lead to a re-pass down the following straight. That would be awesome to watch since it takes a few corners to make a move stick if both drivers take a different strategy.
Belatti
You just cant brake with the wrong brake balance. Corner entry speed would be awful and tyres wont last
Andres125sx
PlatinumZealot wrote:I say increase the fuel flow limit. That is the real enemy here.
+1
De La Rosa said they´re not using the 100kg fuel they´re allowed to use, not in Monza and many more tracks. That´s due to the fuel flow limit.
They don´t reach the 15k rpm limit either because of the fuel flow limit too
So increase the fuel flow limit keeping the same 100kg limit per race, and that will improve the sound because they could reach the 15k rpm limit, the top speeds and the lap times all at once
andylaurence
123
Contact:
If they're not short on fuel, why do they use these fuel-saving techniques? They change engine maps and lift/coast to save fuel.
kooleracer
andylaurence wrote:If they're not short on fuel, why do they use these fuel-saving techniques? They change engine maps and lift/coast to save fuel.
More fuel onboard equals, heavier car equals slower laptimes. Also heavier car means more stress through the tyres. Also the teams use simulators to get the optimum fuel levels for the start.
Irvine:"If you don't have a good car you can't win it, unless you are Michael or Senna. Lots of guys won in Adrian Newey's cars, big deal. Adrian is the real genius out there, there is Senna, there is Michael and there is Newey.They were the three great talents."
NTS
NTS
Belatti wrote:You just cant brake with the wrong brake balance. Corner entry speed would be awful and tyres wont last
Take a look at the Rotax Max Senior kart class, those currently drive without front brakes (used to have them a few seasons ago and didn't have them before that). Sure, I out brake them like crazy in a KZ1 which has front brakes and adjustable balance. But that was the point of my suggestion: gain more power by sacrificing a bit of braking (when balance is set more to the rear) or gain drivability and loose some power (when balance is set more to the front). It's an engineering challenge for which they could find and optimum, which probably differs per track and rewrites more adaptation from the drivers = bigger challenge.
Andres125sx
What kooleracer said. Also, fuel consumption in race is an estimation that may vary a bit. Also, what if there´s a SC? On tracks like Monza where it´s not rare to deploy some SC teams may hope there will be a SC so the put less fuel to gain some weight/time. If then there´s no SC, you need to save fuel
Obviously it depends on the track, there´s some tracks where they need to save fuel even if they use 100kg (a bit more for the warm up lap actually), but from what he says, there´re a lot of tracks where they don´t need any saving technique if using the full tank. In theory of course, Monza didn´t need it in theory and we saw some teams saving fuel because of their too optimistic prediction
Belatti
Not the same as a kart with no aero pitch sensitivity and larger tyre patch vs. weight ratio when you have to slow down more than 200kph. Braking distances would triplicate and rear tyres would be destroyed within few laps, plus the cars would be unstable entering fast corners.
Post Reply
