DRS in Monza/New top speed records?/Best place to sit
darkmninya
darkmninya
-26
Re: DRS in Monza/New top speed records?/Best place to sit
My dream about f1 : 400km/h
Juzh
161
George77 wrote:I just can not believe that combined both engine and the electric motor produce only 750...i believe by the time of Monza they will equal the old V10 units...allready and not pussing 100% Ferrari toped 336+in Bahrain...for Monza they will definetly bring a special aero+the reduced drag i believe we will see a new record.
Wanna bet on it?
George77
George77
YES!
basti313
basti313
25
1. Power will not limit the top speed. Gear ratio will limit the top speed. No one will aim for a record in Monza with a high gear ratio he has to carry through the rest of the season. We will see the lowest top speeds ever in Monza.
2. Test top speeds do not mean anything. Launch spec aero with not enough downforce for the track...Monza race spec will perhaps not be much lower in drag.
Don`t russel the hamster!
OrangeArrows
OrangeArrows
Wanna bet on it?
Are the gear ratios already fixed in testing? same for the fuel flow restriction during resting?
Juzh
161
OrangeArrows wrote:
Wanna bet on it?
From article 9.6.2 of F1 2014 technical regs:
Each competitor must nominate the forward gear ratios (calculated from engine crankshaft to
drive shafts) to be employed within their gearbox. These nominations must be declared to the
FIA technical delegate at or before the first Event of the Championship.
George77
George77
What do you think now about the "top speed" debate? Are we going to see a new record tomorrow?
Gaz.
Gaz.
George77 wrote:What do you think now about the "top speed" debate? Are we going to see a new record tomorrow?
Highest today was 348kph iirc, I don't think we are going to see 373kph tomorrow.
Forza Jules
George77
George77
354 the maximum today quite impressive.
362 km/hr from Ricciardo
George77
George77
As i said, this year we'll see 360-370 at Monza...362 is quite impressive!!!
Belatti
Belatti
360 kph for year 2014 safety standards is quite low, and 1m24s pole position is quite slow, maybe Monza should have a 3rd gear first chicane, a faster 2nd Lesmo and a wider Ascari exit...
Juzh
161
Belatti wrote:360 kph for year 2014 safety standards is quite low, and 1m24s pole position is quite slow, maybe Monza should have a 3rd gear first chicane, a faster 2nd Lesmo and a wider Ascari exit...
No.
SectorOne
Just continue to develop the ERS system. KERS went from 80 to 160 in four seasons it ran so double it again in another four-five years
320 electric horses plus some from the ERS-H for good measure.
Land driven rockets basically.
I say increase the fuel flow limit. That is the real enemy here. Formula 1 should just forget about trying to save fuel. It will be all done in another couple of decades so might as well screw the environmentalist and have fun with it!
