I don't think it's banned.xpensive wrote:So that's what it was all about, clever, no wonder they wanted to spend time on it, such a shame if it was banned?
timbo wrote:I don't think it's banned.xpensive wrote:So that's what it was all about, clever, no wonder they wanted to spend time on it, such a shame if it was banned?
The FIA have ruled that any device that changes the length of the suspension, is in breach of the regs. Not the aero regs, but the suspension regs.Ferraripilot wrote:timbo wrote:I don't think it's banned.xpensive wrote:So that's what it was all about, clever, no wonder they wanted to spend time on it, such a shame if it was banned?
There has been no mentioned of the MB system being banned. Only Lotus/Ferrari had this judgment. I suspect the MB solution is a more integrated passive solution which will pass for being more of a 'suspension system only' which just happens to be adverse to dive by means of being interconnected to the rear. It's probably borderline and might just be banned, but if they already ran it a bit last season I suspect not then, and especially if it's just an expansion for what their rear suspension system was for W02. It's probably not anything like Lotus developed which was a suspenion system+.
I think the mercury is used in the dampers to increase the dampening, not as a fluid to change suspension component geometry.gilgen wrote:The FIA have ruled that any device that changes the length of the suspension, is in breach of the regs. Not the aero regs, but the suspension regs.xpensive wrote:So that's what it was all about, clever, no wonder they wanted to spend time on it, such a shame if it was banned?
So if the Merc system is designed to lift or lower the suspension at any point, it is illegal.
I think that you will find that the use of mercury is also banned, due to its toxicity , and danger to rescuers.dren wrote:
Who came up with this short floor is optimal idea?dren wrote:Sounds like the Ferrari and possibly the Mclaren will have short floors...just like Mercedes tried with its last car, but they will retain a longer wheelbase for better packaging, CofG, etc. The sidepods are moved back with the crash structure up front doubling as wings. Pretty cool. Maybe Mercedes has found a way to retain the optimal short floor while stretching the wheelbase too?
Mercedes last year. Read back on the Autosport Mag article. few pages back I think articleringo wrote:Who came up with this short floor is optimal idea?dren wrote:Sounds like the Ferrari and possibly the Mclaren will have short floors...just like Mercedes tried with its last car, but they will retain a longer wheelbase for better packaging, CofG, etc. The sidepods are moved back with the crash structure up front doubling as wings. Pretty cool. Maybe Mercedes has found a way to retain the optimal short floor while stretching the wheelbase too?
And what's the reasoning behind it?
I believe that Mercedes' idea was that with the enforced lower diffuser, no DDD, it was not enough to accelerate the air under the car enough with the full-length floor, why they shortened it to maintain the speed. Area was reduced, but as static pressure is reduced with square of the air-speed, downforce would still be higher. This was probably supported by the windtunnel, but it was perhaps not necessary to reduce the wheelbase as well, as Ferrari seems to have found out?ringo wrote: ...
Good heavens thats ugly! Not an insult to you, I think you did a steller job! But the look of the thing! Someone beat it with an ugly stick.yace wrote:
hi guys, i made some changes on my drawing of last week. you can see the "dolphin shaped" nose, some changes on the sidepots and others littles details
(i'll try to make an animated gif tomorrow)
I dont see here any advantage, beacuse in case of turnig into corners will provide uneven flow! I think the max lenght of wing pylon has on Ferrari F150th... Just overall this pylons are use to direct much as possible undisturbed flow toward the splitter section etc.NewtonMeter wrote:yace wrote:
BTW, what is the reasoning behind the extended front wing pylons?
aleksandergreat wrote: I dont see here any advantage, beacuse in case of turnig into corners will provide uneven flow!
Why do you think that?I think the max lenght of wing pylon has on Ferrari F150th...
And to generate some downforce by itself.Just overall this pylons are use to direct much as possible undisturbed flow toward the splitter section etc.
