Vodafone McLaren MP4-27 Mercedes
Post Wed Feb 29, 2012 10:46 am
murtoidf1 wrote:F1 Fanatic is not one of the best websites, i agree. I don't go on it at all.
Anyway, what are people expecting McLaren to come out with for the next test? Perhaps a refined exhaust layout?
The pre-season rumors were that they had a "revolutionary rear wing" that would be introduced at the final test or first race.
beelsebob
70
Post Wed Feb 29, 2012 11:40 am
Revolutionary? There isn't too much they can do with rear wings, unless they have a very strange chord shape and flap arrangement. Can't wait to see if this rumour is true though.
Felipe Baby!
SiLo
Post Wed Feb 29, 2012 11:41 am
SiLo wrote:Revolutionary? There isn't too much they can do with rear wings, unless they have a very strange chord shape and flap arrangement. Can't wait to see if this rumour is true though.
That was my thought too, we'll see soon I guess :)
beelsebob
70
Post Wed Feb 29, 2012 5:04 pm
Could you place the DRS flap under the main plane, or am I spouting utter rubbish yet again :)
"Too often we excuse those who are willing to build their own lives from the shattered dreams of other human beings." -Robert F. Kennedy
Shrieker
Post Wed Feb 29, 2012 6:30 pm
Shrieker wrote:Could you place the DRS flap under the main plane, or am I spouting utter rubbish yet again :)
I don't think there would be much point to that as it is effectively an extension of the main plane. As another non expert the way I see it is that when it flips up it becomes aero neutral and at the same time reduces the chord of the main plane and therefore the drag.
Became a McLaren fan in the late 70's when I ended up laminating their Kevlar nosecones.
ianwit
Post Wed Feb 29, 2012 6:39 pm
You couldn't – rule 3.18.1 – The incidence of the rearmost and uppermost closed section described in article 3.10.2 may be varied whilst the car is in motion...
3.10.2 also seems to ban it, as the two have to be close to each other at their closest approach, meaning that you couldn't flip your rear wing otherwise.
beelsebob
70
Post Wed Feb 29, 2012 7:35 pm
Could you shape the actuator in such a way as to bypass the rules regarding 2 elements rear wings?
Nickel
Post Wed Feb 29, 2012 8:23 pm
Scarbs posted earlier this week that he's been told to pay attention to their DRS.
Pup
40
Post Wed Feb 29, 2012 8:31 pm
Nickel wrote:Could you shape the actuator in such a way as to bypass the rules regarding 2 elements rear wings?
I think that style of actuator is only allowed in the central 150mm section
Owen.C93
Post Wed Feb 29, 2012 9:53 pm
And how long before they banned that idea? Need to be a little more clever than that. Your trick idea needs to be politically acceptable to last more than 3-4 races these days.
Brian
hardingfv32
Post Wed Feb 29, 2012 9:59 pm
Interesting, I'm pretty sure the rules governing the rear wing are fairly tight, although they did come up with the F-Duct so I suppose they know where the grey areas are. Does the DRS have to be only the top plane of the wing moving? Could you move the whole thing?
Felipe Baby!
SiLo
Post Wed Feb 29, 2012 10:09 pm
Funny, I was just checking the regs for the same thing - I don't see anything that says you can't have a single wing section; and if you only have one, I don't see anything that disqualifies it from being the section that's moved.
I'm not sure what you'd gain from that, though. Or rather, I'm not sure if what you gain wouldn't be grossly outweighed by what you'd lose.
I'm more curious if something clever couldn't be done with the location of the pivot point. The regs seem to assume that the pivot is always located within the section itself, but I don't think they specifically state that it has to be. That is, you might be able to bracket the wing at the endplates and set the pivot point farther back or higher than the regs assume you could. Again, without having put much thought into it, I don't know what the benefit would be.
Pup
40
Post Wed Feb 29, 2012 11:00 pm
Pup wrote:I'm more curious if something clever couldn't be done with the location of the pivot point. The regs seem to assume that the pivot is always located within the section itself, but I don't think they specifically state that it has to be. That is, you might be able to bracket the wing at the endplates and set the pivot point farther back or higher than the regs assume you could.
What about further down? If the pivot was located towards the center of the wing section. I believe the rules specify the maximum allowable travel for the leading edge of the wing section, which is why a shorter element yields greater drs effect, but if it pivoted in the center, this would allow a much bigger section while still lying flat when the drs is activated.
Nickel
Post Wed Feb 29, 2012 11:02 pm
The pivot point is restricted.
Post Wed Feb 29, 2012 11:03 pm
Pup wrote:Funny, I was just checking the regs for the same thing - I don't see anything that says you can't have a single wing section; and if you only have one, I don't see anything that disqualifies it from being the section that's moved.
3.18.1 third dash demands that if you want to move part of the wing, you must have exactly 2 closed sections.
That's an interesting point, I don't see anything banning having an upper flap that's essentially long chord, in that it's a long way from the pivot to the front, but also short chord in that there's not much surface on it. I don't know what you'd gain though – it would seem that would get all the disadvantages of both wouldn't it?
beelsebob
70
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: Google Adsense [Bot], kwanchepan and 13 guests
