Ferrari F2012
Post Thu May 24, 2012 10:22 pm
Im pretty sure he's using them, just the angle
Mesteño
Post Thu May 24, 2012 10:55 pm
There there, they're there.
bhallg2k
147
Post Thu May 24, 2012 10:57 pm
Only difference are the mirrors. And im sure hamilton likes that
wrcsti
Post Thu May 24, 2012 11:25 pm
italian wrote:Today we have seen two different configurations for the mirrors:
Massa:
[img]http://i.imgur.com/nsmaM.png[img]
Alonso:
[img]http://i.imgur.com/tje6Z.jpg[img]
The difference is obvious; the taller mirrors work better for checking who may be lapping you, while the wider mirrors work better if you're on the lead lap and are check to see who it was you just passed.
Reason: disabled img tags. no need to quote the large images so often
CmdrVOODOO
Post Fri May 25, 2012 1:48 am
Massa:
Alonso:
Could be the angle, but in those pics it seems Massa is not using the additional cooling openings in the sidepods, which Fernando is using...
Massa is using also cooling openings at the side pods. The only difference is the height of the openings. In Massa's car the openings is uniform while in Alonso's its ascending. (judging from the pics)
nhojekim1223
Post Fri May 25, 2012 2:01 am
That's just the angle.
Owen.C93
Post Fri May 25, 2012 4:55 am
Same cooling, different height on mirrors.
Nando
Post Fri May 25, 2012 8:04 am
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
alogoc
-10
Post Fri May 25, 2012 8:49 am
wrcsti wrote:Only difference are the mirrors. And im sure hamilton likes that
The fins under the nose are different too. Alonso is using the classical Ferrari L shaped, Massa the curved RB style ones
.poz
Post Fri May 25, 2012 9:28 am
alogoc wrote:http://s5.as.com/recorte/20120525dasdaimot_1/H380/Ies/20120525dasdaimot_1.jpg
http://www.yallaf1.com/wp-content/theme ... h=380&zc=1
Ferrari decides to abandon high rear rake philosophy!?
Could be the track not feeding the diffuser enough air so they have to lower it to optimize it?
Nando
Post Fri May 25, 2012 10:14 am
And surely it's also a case of Ferrari wanting to raise the front height in order to better ride the curbs in Monaco. Obviously if the front is raised then the rear would have to be ridiculously high to maintain the rake.
f1316
Post Fri May 25, 2012 10:20 am
It's likely that their mechanical setup for Monaco with the various spings and ARBs mean it has to run that way too.
失败者找理由,成功者找方法
raymondu999
105
Post Fri May 25, 2012 12:45 pm
The F2012 is still running rake. I will post better picture after work.
Crucial_Xtreme
68
Post Fri May 25, 2012 12:46 pm
"Results never tell the full picture. You need to take a close look at the story behind those results." raymondu999
FrukostScones
Post Fri May 25, 2012 1:19 pm
you calling that a aero rake, only because Monaco is track with many bumps car have this rake. if you compare their rake with lotus or mclaren you will see it's almost insignificant. sure, maybe i'm wrong...
Neno
-22
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: boyracer94, f1316, Google Adsense [Bot], kilcoo316, kwanchepan, R_Redding, Valentino and 19 guests
