Red Bull RB8 Renault
Post Reply
Pierce89
Re: Red Bull RB8 Renault
atanatizante wrote:A slightly big hole for the upper wishbone, don`t you think?
Maybe it works in conjunction with the concave rear crash structure and the slot in the wing beam?
that would be the LOWER wishbone
Onch
Contact:
That would be the driveshaft...?
the hole you see is for the driveshaft which is in line with the lower wishbone methinks.
munudeges
-14
A lovely, elegant, and as usual, simple solution. The angle they have the bodywork at behind the exhaust has been very well thought out and means they should get some nice attachment to get their exhaust flow to where they want it to go - lower down. They've put a lot of thought into this and there should be a lot of development mileage.
CHT
CHT
-6
RB8 v1.0
RB8 v1.1
OO7
OO7
171
It looks to me like RBR with this exhaust design may be try to split the exhaust flow, by:
1) Having part of it spill over the outside of the side pods and travel towards the outer part of the diffuser, in an attempt to partially seal it.
2) Having the rest of the flow follow the contours over the top of the side pod and end passing over the diffuser and into the starter hole.
CHT
CHT
-6
perhaps is to cool the gearbox
Pierce89
marcush. wrote:the hole you see is for the driveshaft which is in line with the lower wishbone methinks.
possibly. Point is, it's DEFINITELY NOT the upper wishbone
atanatizante
107
sorry, my bad!
+1 marcush
Jesus
foxmulder_ms
Quite a radical change on the exhaust area and sidepod...
atanatizante
107
Red arrow is what was Marcush said about ...
Blue arrow is there a slot also? Like Ferrari is doing?
Purple arrow is for the new vane above the diffuser.
I might be wrong but seems to me that it has 2 purposes:
1)To divert the exhaust to the outer diffuser limits in order to create an air skirt, like they did last year,
2)To work in conjunction with the lower part of the RW end-plate, improving air extraction from the gills further down attached to it, hence a better diffuser ...
The rear brake wiglets has something to do with sealing the diffuser or just for giving them better rear DF ? ... or both?
Jesus
raymondu999
Does anyone have a comparison from-the-top view of the old and new sidepods? I'd love to see how much wider they've become.
失败者找理由,成功者找方法
Owen.C93
171
Old:
New:
AnthonyG
38
marcush. wrote:
AnthonyG wrote:Wondering: are there any FLIR shots of this car (and others)?
I think a FLIR camera would point out instantly how the exhaust flows. (and some other airflows)
thermal imaging does only show surface temps you might or might not get a hint were the exhaust gas is going.
No it doesn't
I've seen (on discovery channel) how with a FLIR optic a spotter can follow the path of a bullet.
So why wouldn't we see where the RB8 blow's it's exhausts? :wink:
Owen.C93
171
No it doesn't
Trying to capture hot air against a very hot and nonuniform body work behind it would be very difficult.
It works when there's nothing behind the hot gas sure.
Post Reply
