Froggolo wrote:beside i also agree it is an air intake and not a reflection,
can someone tell if in the 2013 rules is it allowed to have air intakes in the front of the car
except the one for cooling the driver?
3.7.3 Forward of a point lying
450mm ahead of the front wheel centre line.....
3.7.8 Only a single section, which must be open, may be contained within any longitudinal vertical cross section taken parallel to the car centre line forward of a point
150mm ahead of the front wheel centre line, less than 250mm from the car centre line and more than 125mm above the reference plane.
Any cameras or camera housings approved by the FIA in addition to a single inlet aperture for the purpose of driver cooling (such aperture having a maximum projected surface area of 1500mm2 and being situated forward of the section referred to in Article 15.4.3) will be exempt from the above.
it's always xxx mm ahead the front wheel center line and F138 intake is more or less aligned with front wheel center line
