Sauber C32 Ferrari
Re: Sauber C32 Ferrari
United States 2013 - Thursday (14.11.2013)
CMSMJ1
CMSMJ1
One of the best tech threads - this car is great
Thanks stefan and others for puting the effort in to post. =D>
IMPERATOR REX ANGLORUM
slimfitcasual
Cleanest car in the grid this year for sure!
Anyone know if all the carbon weave is really necessary though? The cycling industry has gone away completely from carbon weave on high end road bikes to save grams, opting for the raw marbly looking carbon layups.
McLaren's own collaboration with Specialized for example.
Per ardua ad astra
trinidefender
trinidefender
317
slimfitcasual wrote:Cleanest car in the grid this year for sure!
http://pedalmag.com/wp-content/uploads/ ... en-2.2.jpg
As far as I know, what you see on the bikes is a graphite (or something else) material on the outside of the carbon fibre. The whole idea about carbon fibre reinforced plastic (CRFP) is that it is carbon fibre weave soaked in resin then cured in an oven. Similar to fibreglass except that fibre glass is exactly that, long strands of glass woven together then soaked in resin. Also it doesn't need to be placed in an oven to cure properly.
The material you are seeing there is probably a protection layer instead of using a thick layer of resin on the outside or paint.
neilbah
neilbah
i read this after reading your question, might provide some answers http://www.velocite-bikes.com/carbon-fiber.html.html
'The high importance of laying down patches of carbon fiber prepreg in different orientations is due to carbon fiber having maximum strength only along the lengths of the fibers. This also helps illustrate why using uni-directional fiber instead of woven carbon fiber (eg. 1k, 3k, 12k) creates stronger frames'
'the main use of woven carbon fiber when it comes to bicycle frames is for appearance. 1k, 3k, or now more rarely 12k carbon fiber is used on the surface of the frame to give it a more uniform carbon look'
trinidefender
trinidefender
317
Been doing some reading. It seems that uni-directional cordon fibre is very strong along its axis in tension loads. However a major downside seems to be its weakness if:
1. Off axis loads are present, all of which will occurs in a F1 cars suspension.
2. If a single strand is broken it compromises the strength of the strands next to it and placing all the load in that area on the resin.
3. Unidirectional CFRP doesn't seem as strong with bearing loads.....well what do you think the suspension connects to....bearings.
Woven carbon fibre seems to work very well in most applications because:
1. It is very strong in off axis loads, such as in suspension movement.
2. It is very stiff in off axis loads, again, such as in the suspension.
3. It retains almost all of its strength even if part of it gets punctured or a strand gets broken.
4. Since if works well with off axis loads, it is easier to predict how it will react and you will have to spend less R & D time and money on working out all the forces and the level of the forces involved to pick where exactly you can use unidirectional and where you have to use woven. This will make the quick production of parts easier, cheaper and faster.
emmepi27
emmepi27
141
No curvy rear wing in Austin
Brazil 2013 - Thursday (21.11.2013)
thisisatest
thisisatest
trinidefender wrote:Been doing some reading. It seems that uni-directional cordon fibre is very strong along its axis in tension loads. However a major downside seems to be its weakness if:
suspension arms are generally loaded in direct compression/tension. a tube made with unidirectional carbon isn't going to have every layer in only one direction. you orient different layers according to the requirements of the structure. weave is generally much tougher at the expense of stiffenss, and is more resistant to crack propagation. so you could see a single suspension arm built with mostly unidirectional fibers (some at 30 or 45degree angles, esp if there is some torsional load), and then at connection areas with hard points you will supplement with weave. the hard point areas are sometimes cut, drilled, machined before bonding to its mate.
for a given strength and stiffness requirement, if you made a tube with nothing but weave, it would be much heavier than one made with unidirectional fibers.
trinidefender
trinidefender
317
By making the suspension members out of multiple layers of unidirectional CFRP with most in alternating directions then you are mimicking have carbon fibre weave is. To do what you want to do will probably come out to a similar weight because of the added layers that you will have to use in a cross pattern relative to the other sheets. Think about it. For example, say you have 5 layers of CFRP weave then they can all be layered on top of each other and be very strong and fairly light with a good resistance to crack propagation. Now take the same situation with the difference being you have 5 layers of unidirectional CFRP. Each successive layer will be placed in a different direction according to your needs. This will probably be very light and quite strong once their are no forces that weren't predicted. This will probably result in a slightly lighter part yet be suceptable to damage.
I wouldn't be surprised if the core of the suspension members is made using unidirectional CFRP and with the outer 1 or 2 layers using CFRP weave to support any unusual loads and to protect the inner layers from damage.
I have worked with a lot of fibreglass and some CFRP, however only variations on weave CFRP, never tried working with unidirectional CFRP.
do you think this can be used as a method by teams?
come on...
the layup of fibres is an engineering process from start to phasing out the end product from its service life.
You do of course choose UD fibre spread tow tapes -to optimise your layups for the expected loads and it is not a bad idea at al to cover it all with a isotropic weave to cater for unexpected random events -like debris hitting the part-
you would surely not be prepared to manufacture a structural part from an isotropic weave...you would simply give away too much of carbon fibres advantages +the ondulated fibres in the weave simply do not perform to the max.
One reason for "textreme" weave we see now on all flat panels .
http://www.oxeon.se/index.php?page=textreme
SectorOne
talk about a difference in the cooling needed for the brakes. Almost completely closed off for the Sauber during the wet.
slimfitcasual
Here's to the 7th best ride, (and in my opinion, best looking car this year) the 2013 Sauber C32! =D>
Per ardua ad astra
Huntresa
Huntresa
This car is indisputedly the best looking car this year but also the one i felt let me down the most, if only they had had the pace to start with, what a good season this could have been...
xDama
xDama
Huntresa wrote:This car is indisputedly the best looking car this year but also the one i felt let me down the most, if only they had had the pace to start with, what a good season this could have been...
+100
I had high hopes for Sauber/Hulkenberg, but the car/tyres let me down. But I enjoyed the last couple of races a lot!
"I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver." - Ayrton Senna
