Williams FW37 Mercedes
Post Reply
fw37
Re: Williams FW37 Mercedes
http://1.bp.blogspot.com/-mBpZLHfT_Wk/V ... 6fe187.png
Matt Somerfield
Williams have an array of updates to assess at this 3rd test one of which is a new set of bargeboards. As we can see in the inset, the team have serrated their bargeboards in a similar way to what we have seen Red Bull, Toro Rosso, Lotus and Mercedes do before. The serrations inject airflow from one side of the bargeboard to the other, energising the region and widening their operating window. This is of particular use at lower speeds as flow tends to become detached, as it cannot overcome the angle of attack and/or surface length as effectively. The changes to the bargeboards come at the same time as other components around the sidepod are altered.
Raleigh
29
Larger outlet for the rear bodywork?
Supports the idea that they (like Mercedes) have cooling packaged above the engine.
old
new
fw37
Matthew Somerfield
https://pbs.twimg.com/media/B-yPJbeUAAA5re0.jpg
Williams had up until now been the exception to the rule on the grid, as their rear wing remained pylon-less up until this test. The team have a totally re-designed rear wing here in Barcelona though, as many of the features that meant it didn't run a pylon can be traded off in the re-design. The pylon is an inverted Y-Lon, mounted to the crash structure it adds rigidity to the rear wing, whilst circling the exhaust. The exhaust plume will likely interact with this section and pull airflow through it (like an aspirator) assisting in cooling the rear of the FW37. The upper section of the Y-Lon has a swan neck style design, which connects with the DRS actuator pod, leaving the underside of the mainplane less affected by its wake. - See more at: http://somersf1.blogspot.com.es/2015/02 ... K7k3w.dpuf
http://3.bp.blogspot.com/-UbeCDPx_EBc/V ... 1fe252.png
The rigidity added by the Y-Lon means the team no longer need to run the floor level wing they ran during 2014 (above, yellow), giving them more scope in terms of diffuser design. - See more at: http://somersf1.blogspot.com.es/2015/02 ... SnASK.dpuf
http://2.bp.blogspot.com/-XxcAasF_XdA/V ... 6fe198.jpg
As we can see in the inset above, the team have either opted to change the length of the endplates and/or the suspension layout, as the lower rear suspension elements now pass through the endplate.
The teams overall change in tact to change the rigidity of the rear wing will mean that they can make shape/geometry/weight changes to the endplates going forward, that may not have been possible with their previous specification. - See more at: http://somersf1.blogspot.com.es/2015/02 ... 9CFeu.dpuf
LookBackTime
472
Raleigh wrote:Larger outlet for the rear bodywork?
old
http://www.formula1.com/wi/enlarge/sutt ... 20fe18.jpg
new
http://www.formula1.com/wi/enlarge/sutt ... 6fe221.jpg
They cut back the engine cover more till you can't see the "V" of the martini stripes.
Raleigh
29
I'd say so too, but if you compare this pic of the old bodywork with LookBackTime's picture 2 posts up looks like the same length...
Probably just as well, there isn't much left to cut away :D
roadie
39
The may be testing the larger outlets that they usually run at the warmer races?
Raleigh wrote:I'd say so too, but if you compare this pic of the old bodywork with LookBackTime's picture 2 posts up looks like the same length...
https://pbs.twimg.com/media/B-Wp8FAIgAAhJa4.jpg:large
AJust look of the meeting point of the dark blue Martini stripes above the exhaust....
LookBackTime
472
Thefuelman
1:23.516, finally some speed. They had me worried there. :shock:
FrukostScones
162
LookBackTime
472
Massa confident of rear wing breakthrough for Williams
http://www.gptoday.com/full_story/view/ ... _Williams/
roadie
39
Nice shots of the rear floor area/diffuser there. I feel the floor may now be lighter and you can see the stays supporting it from the rear crash structure.
I think the team's quiet work ethic is something to be confident about :)
LookBackTime
472
LookBackTime
472
Post Reply
