Mercedes AMG F1 W06
Post Reply
dans79
267
Re: Mercedes AMG F1 W06
Does the Merc still have the carbon fiber transmission housing? If so, I wonder if they will adjust the suspension geometry, so they are easier on the tires, come Spain.
197 104 103 7
Rear "cutouts" from above
Cocles
dans79 wrote:Does the Merc still have the carbon fiber transmission housing? If so, I wonder if they will adjust the suspension geometry, so they are easier on the tires, come Spain.
As far as I know, yes. I think Ted Kravitz actually showed a photo of it at testing, during one of his notebooks.
This is from Bahrain, any Ideas what the Red Thing is? Is it to Protect the RW Support while the Car is assembled or did they Laminate some Carbon on the Support, maybe for a Monkey Seat as the cutout would suggest?
astracrazy
31
hmm bit strange. Looks to me like they have either had to repair something or add/remove something. Maybe they had to cut out a bit of the support (hence the shape)
The rear wing can be completely dismantled so I can't imagine it would be for travel and even so i would think the protection would come from the case its put in not from something attached to it
Sonic
If you look at the upper part, there's a cable. Maybe it's a support for a sensor on the upper wings ?
astracrazy
31
Sonic wrote:If you look at the upper part, there's a cable. Maybe it's a support for a sensor on the upper wings ?
that's not a cable its part of the wing
Sonic
Sorry ! :D
Sonic
Repair (stick a broken piece or add a new piece) ? Probably.
aleks_ader
90
Sonic wrote:Repair (stick a broken piece or add a new piece) ? Probably.
Probably yes. Remember they had "monkey seat" failure (broke off) already in Barcelona preseason test.
EDIT 1: Look they added bigger bulge part near "monkey" seat pelican support attachment point.
Could we see last years "monkey throne" again. If i remember well on W06 i dont see that last years feature very often until this season.
Sonic
You're probably right. It's the best option.
AnthonyG
38
Perhaps that red thing is just a strut so that they can remove the rear wing sideplates.
dans79
267
I was thinking it was just an alignment/support jig till the entire wing was assembled!
197 104 103 7
FrukostScones
162
Jolle
Clearly this is for transport and/or assembly. Because the cars were not send back to the factory between GP's, the car is only partly torn apart for transport. Also, prob as you work on the car, it's just to easy to bump into the central support, damaging or chipping it. That's also why it's in "remove before flight" red.
If it was a repair job, it would be Merc unworthy and would make no sense to do it on the car like this, it should be done in the oven (and taken apart).
Post Reply
