Lotus E23 Mercedes
Re: Lotus E23 Mercedes
Malaysian GP - Thursday
Via AMuS
chuckdanny
chuckdanny
69
I didn't know they use golf ball dimples on the top of sidepods, i heard about it of course, it's to prevent or delay separation but never saw it
timbo
timbo
111
chuckdanny wrote:I didn't know they use golf ball dimples on the top of sidepods, i heard about it of course, it's to prevent or delay separation but never saw it
http://img3.auto-motor-und-sport.de/GP- ... 853047.jpg
Maybe it's just a different (perhaps lighter) carbon fiber weave? Not everything has to be aero related.
Thefuelman
Thefuelman
I remeber something about this from back in the 90's. some team in '96 wanted to do it, Tyrell I think because they were so down on HP from the Yamaha engine and the FIA very quickly put a stop to it because nobody wanted ugly dimpled cars. Maybe its just a hastily repaired panel on pastors car after his crash in Australia or just a bad finish?
Tim.Wright
330
That type of finish occurs when you pull too much resin out of the laminate during the cure cycle. The fibres close to the mould surface become almost dry of resin and you get a patterned texture in the shape of the weave.
I assume that they didn't have the time or the inclination to fill it before painting it.
It can be fixed in subsequent parts by changing the vacuum bagging assembly, the clave pressure or even changing the material but it doesn't make sense to scrap a non structural part because of a bad surface finish. The aero effect I'm sure is negligible.
chuckdanny
chuckdanny
69
Well every part in contact with air has to do with aero but ok it could just be that it doesn't change much aero caracteritics.
A piece of wood, balsa or something found on the way. They are so much in need of money. Maybe it's recycled coffee plastic cup :lol: .
Last year they tried asymetrical things and even a real quit big bump on the roof, being so much behind the E22 was a real laboratory.
WBF1
WBF1
There is a possibility that particular part was not post cured to a high enough temperature. The other components around the sidepods are all smooth.
If laminates are exposed to higher temperatures than the post cure temp the resin can soften and start to "flow" exposing the laminate pattern (print through). Dark colours are more prone to this, and the part in question I believe would be in the vicinity of one of the radiators.
outer_bongolia
Tim.Wright wrote:I assume that they didn't have the time or the inclination to fill it before painting it.
What's the point of fixing dents in Pastor's car anyway? :roll: :mrgreen:
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
3jawchuck
3jawchuck
37
WBF1 wrote:There is a possibility that particular part was not post cured to a high enough temperature. The other components around the sidepods are all smooth.
Could Maldonado's bodywork incident in FP2 be caused by this?
joetoml1n
Doutful!
Also, in the set of pics that contains the one of the bodywork you're refering to; you can see it is car #8 - Grosjean
3jawchuck
3jawchuck
37
Doutful!
OK Thanks.
As for which car it is, I was just assuming they are both made in the same way and if any weakness in the process existed it would be present in both.
AlainProst
AlainProst
-13
Have they changed something since last race in Australia aerodynamically ?
I don't see anything of difference but I may be wrong...
R_Redding
R_Redding
3jawchuck wrote:There is a possibility that particular part was not post cured to a high enough temperature. The other components around the sidepods are all smooth..
It looks like the mold or former has not been " gel coated" before the fibres were applied.
https://en.wikipedia.org/wiki/Gelcoat
Gelcoat is used to smooth the surface so it does not give a raw or mild "orange peel" look and feel.
Rob
AnthonyG
38
I read something about Maldonado driving around with bodywork off/loose. Anyone has pictures of that?
Richard
Richard
Sponsor conversations are in the team thread :arrow: http://www.f1technical.net/forum/viewto ... ead#unread
