Renault R.S.16
Post Reply
Contact:
Re: Renault R.S.16
Seems like the PU upgrade tested this week had a positive feedback both in terms of diveability and performance. Looking forward to see how this translates in time during the Canadian Grand Prix.
GoranF1
155
Contact:
Re: Renault R.S.16
Re: Renault R.S.16
Kiril Varbanov
147
Contact:
Re: Renault R.S.16
Here's a live shot of a RS car, this is from their show room at Champs Elysee. It is amazing how big is that car in live.
https://twitter.com/Kiril_Varbanov/stat ... 5631810560
Formula Wrong
Contact:
Re: Renault R.S.16
Palmer will get a new chassis for Montreal. Not surprising after seeing the heavy damage his car suffered.
By the way, does Renault use something like a vanity panel? There seems to be a part of the monocoque being broken off the rest but it doesn't belong to the nose cone:
If you no longer go for the space someone always has to leave, you're no longer a racing driver
JDC123
30
Re: Renault R.S.16
Formula Wrong wrote:Palmer will get a new chassis for Montreal. Not surprising after seeing the heavy damage his car suffered.
http://i.imgur.com/7W1c3Qc.png
Yes Renault use a vanity panel, you can see it here:
Still incredible how easily the chassis damaged considering it was relatively slow compared to impacts we've seen in the past.
You can clearly see the chassis is damaged were the L of 'Renault' is between the vanity panel and access hole.
RicME85
52
Contact:
Re: Renault R.S.16
I too was surprised at the damage done to the front of the tub but thinking back, the first contact partially detached the nose so when the second impact happened the nose came off completely and the front of the tub took the majority of the load instead of the nose.
Still, its no wonder Palmer has bruised feet.
Re: Renault R.S.16
Re: Renault R.S.16
absbeginner
Re: Renault R.S.16
RicME85 wrote:I too was surprised at the damage done to the front of the tub but thinking back, the first contact partially detached the nose so when the second impact happened the nose came off completely and the front of the tub took the majority of the load instead of the nose.
Chassis failure has probably been caused by wheel cables.
When the car hit the barrier the load on right front tire ripped off the entire nose.
patrik
Re: Renault R.S.16
ME4ME
79
Re: Renault R.S.16
They're pre-heating the brakes. Part of tyre pressure management.
Nathanael F1
Re: Renault R.S.16
Kiril Varbanov wrote:Here's a live shot of a RS car, this is from their show room at Champs Elysee. It is amazing how big is that car in live.
That just looks like a showcar - notice how the nose is completely different.
DiogoBrand
73
Re: Renault R.S.16
It is.
domh245
30
Re: Renault R.S.16
It is.
Specifically, it is a Lotus E22, with the COTA test nose fitted. Same car that was used for this photo
Post Reply
