McLaren MCL32 Honda
Re: McLaren MCL32 Honda
@proteus: They're obviously Prototypes, don't act like that's something new in F1.
Jef Patat
Jef Patat
Thunders wrote:
23 Mar 2017, 16:06
Thunders, don't ask rhetorical questions :P
I'm a bit amazed that the bargeboards also look unfinished (sandpapered) while at the same time not looking new.
proteus wrote:
23 Mar 2017, 16:05
I am concerned about the finish on this carbon fibre parts, they are not coated with resin and polished, they are just simply grinded and left like this. aparently this really are one-off parts which will be thrown away as soon as possible - atleast it seems so.
Like Thunders already explained, these are most likely parts which have been rushed, with no time for resin and polishing. It's something we very often see for the first race of the season. Back in 2011, McLaren rapid-prototyped a complete diffuser out of titanium.
Removing a couple of posts rambling about how basic parts look. Talking about parts finishes is allowed in the context of its functionality and preparation.
ncassi22
ncassi22
31
Love those! They seem to still be doing correlation - Hence the spec 1 Johny Walker bargeboards. Also a good idea as Aus P1 is usually slippery and useless for setup.
ScrewCaptain27
577
Copyright @ScarbsTech
- Serj Tankian
Goran2812
Goran2812
27
That floor... so basic...
Can someone explain what that winglet infront of the rear tires does?
Visit my photo page! -> http://www.gorankphoto.com/formula1
Coefficient
Coefficient
Some of the marks are where they haven't cleaned flow vis off properly.
proteus wrote:
23 Mar 2017, 16:05
mclaren knows what they're doing, no need to be concerned. you should be concerned if they mounted bumpers and directional indicators.
also, if there is no actual benefit from coating it with resin and then polishing the resin, then why do all that effort?
you could for example reason that if you can be sure that coating and polishing it has no actual aero benefit, or discardable, then you might actually win some weight back by the amount of parts you decide not to coat. a few hundred grams dont neccesarily look like much, but if it is for multiple parts, you save quite a good amount and above, you can argue, you can lessen the stress on your driver's diet and have him loose 200 grams body weight less.
there's something to say for anything. something that doesnt look fantastic doesnt neccesarily be bad.
Jef Patat
Jef Patat
The flat bits on the outer diffuser edge seem to be gone again, I never understood how that was supposed to work.
SR71
proteus wrote:
23 Mar 2017, 16:05
I'm not sure you understand how modern CF parts are made but not one part of your comment likely applies.
Most of these parts will be made from pre-pregnated carbon fiber.
Why would u want to add additional resin and weight for no reason?
GhostF1
GhostF1
110
Goran2812 wrote:
23 Mar 2017, 18:31
Just pure speculation here... but that winglet might be something to kick the airflow upwards into the air barrier which appears around the tyres when at speed which would likely be a method of drag reduction rather than letting the air smash into the tyre causing unnecessary turbulence.
That's just where my brain is going with that.. it's possible i'm completely wrong haha
proteus
22
SR71 wrote:
23 Mar 2017, 21:33
proteus wrote:
23 Mar 2017, 16:05
Why on earth would u think about the structural integrity of the carbon fibre parts? I wasnt implying that those parts are held together by some science fiction force/material. I know how the carbon fibre parts are manufactured. It was only an aesthetic view of the matter.
SR71
proteus wrote:
24 Mar 2017, 00:42
SR71 wrote:
23 Mar 2017, 21:33
proteus wrote:
23 Mar 2017, 16:05
You know how carbon fibre parts are manufactured yet ask why there is no outer clear layer of resin. All pre-pregnated carbon fiber comes out with a thin layer of resin on the outside surface.
Every piece of carbon fiber on that car has an outer layer of resin. It might only be a few microns thick but it's there.
