Red Bull RB5
i70q7m7ghw
i70q7m7ghw
49
Re: Red Bull RB5
wesley123 wrote:
Diesel wrote:I don't like the way RB are so fickle with their engines, they just jump on what they think is best without an regard for contracts etc. They used a loophole to dump the Ferrari engines on STR.
If the engines are to be 'equalised' RB would be better off sticking with the Renault engine which they already know rather than using something else and having to redesign a chassis around it.
that is true, but the associated merc engines with it require far less cooling, so even smaller sidepods are possible.
In surface area I'd say the opening on the Red Bull is similiar in size to that of the Brawn. In profile it's very different, but I think that's more to do with the aero concept of low sidepods. Brawn have a different concept with higher sidepods which are heavily undercut with a slot McLaren style opening for cooling.
BreezyRacer
BreezyRacer
Re: Red Bull RB5
I would be willing to bet that next year's RB will have a higher tail than this year's car. It'll be better for the diffuser and they will also need some packaging miracles to contain all that fuel. I wouldn't be surprised if the sidepods were further forward as well, in an effort to get weight as far forward as possible in the chassis. It will be a very different car.
It's conceivable that the now empty area above the center splitter area could contain a second fuel tank. Then add a method of selectively controlling the fuel level between tanks to control the balance as fuel loading changes and you presumably have a pretty good setup for controlling car balance thru the race.
axle
axle
Re: Red Bull RB5
Newey originally picked the Renault as it had a low thermal output and needed less cooling. So I don't buy that the Merc needs less cooling capacity.
- Axle
deus1066
deus1066
Re: Red Bull RB5
I thought Newey picked Renault engines originally, due to his preference of the working relationship with Renault going back to his Williams days.
http://f1update.com/full_story/view/191 ... t_engines/
Keir
Re: Red Bull RB5
BreezyRacer wrote:I would be willing to bet that next year's RB will have a higher tail than this year's car. It'll be better for the diffuser and they will also need some packaging miracles to contain all that fuel. I wouldn't be surprised if the sidepods were further forward as well, in an effort to get weight as far forward as possible in the chassis. It will be a very different car.
I would suggest that the teams would be looking to move weight back next year due to the relatively dimunitive nature of next year's front tyres.
BreezyRacer
BreezyRacer
Re: Red Bull RB5
You could indeed be correct. We'll have to wait and see, but remember that next year they are lugging around twice as much fuel and will need to be able to control the chassis balance on min and max fuel loads. Putting all that at the rear will make for a very unbalanced car as fuel loads change. Also another reason to move sidepods forward can be found here ..
viewtopic.php?f=6&t=7580&p=131202#p131202
Keir
Re: Red Bull RB5
axle wrote:Newey originally picked the Renault as it had a low thermal output and needed less cooling. So I don't buy that the Merc needs less cooling capacity.
That is true, however ... cast your mind back.
When the decision was made by Red Bull:
* the Renault V8 was coming off the back of a championship winning season with no restrictions on engine development
* it had a low level of heat discharge compared to its nearest rival (at that time the Ferrari V8)
* the 2006 Merc V8 was a bit of a hound
An intentsive winter programme, the freeze on development and the restriction to 19,000 rpm all helped the Merc in relation to the Renault and the Ferrari and at the mandated lower RPM it became significantly more efficent for the heat produced than the Renault or the Ferrari.
Re: Red Bull RB5
dount that, i mean, Renaults sidepods are huge, Renault cut the sidepods open way before the rear wheels only to get an large enough hole. all the 3 mclaren teams had small sidepods, mclarens were small, force india was small after the upgrade, and branw gp's sidepods were one of the smallest, im pretty sure the mclaren needs less cooling. The brawn had the smallest after Red Bull but didnt have any heat problems, do you guys remember how the Red Bull airbox was cut open at certain grand prix? never seen that at the other teams, alot of people added question marks to Red Bulls finishability in hot races.
Re: Red Bull RB5
I don't think so.. There was a thread with pictures posted.. the Renault has the smallest side pod openings.
Almost like cat nostrils.
*edit i noticed you said side pod size... Better if you could see the size of the radiator itself.. but I doubt the radiator cooling is insufficient in all the cars today. The efficiency of the engines can't vary that much can they?
The redbull and Reanult have Humongous holes in the back.. This could mean that the sidepods were backing up the air because of the small waist size.. It could be from the exhaust manifolds too.. hmm..It probably isn't right for us to guess about these things... :-k
Re: Red Bull RB5
to go and discuss about the size is actually pretty useless, the shape is completely different. Also the rest of the mechanicals are important for the cooling, i believe also how the exhaust is placed, might be that Newey could plan that better with a Renault engine
ESPImperium
ESPImperium
64
Re: Red Bull RB5
Im wondering, could that massive hole thats on the back of the Red Bull been running all season for numbers for a innovation for 2010??? I think that he has been looking at providing a single exaust outlet for both sides of the engoine and that coule be where it is going.
Webber has had development parts on his car since Singapore seemingly.
Dmitry
Dmitry
Re: Red Bull RB5
Interesting appliance (Jerez tests):
Oscillation measurement? Are there any ideas?
Fil
Re: Red Bull RB5
Dmitry wrote:Oscillation measurement? Are there any ideas?
Apparently RB run a lot of ballast in their front wing, this is probably an opportunity for them to measure just how much movement this added weight is causing.
Any post(s) made by this user are (semi-)educated opinion(s), based on random fact(s) blurred by the smudges of time.
Any fact(s) claimed by this user will be supplemented by a link to the original source of said fact(s).
machin
162
Re: Red Bull RB5
My initial thoughts were the saem.. some sort of load/defelction measurement... but maybe its a bit more simple:-
Perhaps the drivers were complaining about variable front end grip and it was guessed that this might be due to the front wing flexing... so they came up with this arrangement to temporarily stiffen up the wing and see if this was in fact the reason..... Maybe????!
Fil
Re: Red Bull RB5
problem is cables won't stop the wing flexing up, only down.
actually, looking at the bottom two photos, those cables aren't even tensioned..?
