[MVRC] Mantium Virtual Racecar Challenge 2016
CAEdevice
47
Contact:
Re: [MVRC] Mantium Virtual Racecar Challenge 2016
Sorry rjsa, I don't know how to help you, but I will look at the steamlines in Paraview when I will find some free time.
Let me change the topic: I would like to be in Monza next weekend for the WEC prologue (probably on Sunday), is someone else planning to be there?
rjsa
51
Thanks.
It sometimes gets frustrating. I changed something across the car and now I get a 15% increase in drag and some crazy uNear areas on the report or a drop in the HX flow. I can just roll back but boy, it was promising....
I'd love to but it's a bit of a long haul from Brazil :wink:
CAEdevice
47
Contact:
Do you use surfacelic? It is not the same as streamlines, bit it helps. You should start loading the "near wall" velocity file you can find in the "surfaces" directory.
rjsa
51
Yep, this rearview/fender interface was fine, then it just started this crazy whirlwind...
CAEdevice
47
Contact:
Maybe the wheel rotation has something to do about it. BTW: neat geometry.
rjsa
51
tks ;)
RicME85
52
Contact:
I have had issues with not being able to get streamlines to show in Paraview with some of my MVRC .foam files
rjsa
51
And did you find a pattern on what works? I have started trying it now, don't even know if I have h right meshes on...
rjsa
51
I got it now, need to turn on internal mesh.
I need a new computer, the 2009 iMac is taking a beating...
rjsa
51
Ooh this is so sweet...
I delivered the first graduation project in my school using CAD back in 1992. We couldn't dream of this, be it SGI, Intergraph, IBM or VAX we where playing with - let alone Microstation 4.0 in a PC.
We barely had access to the ship model basin. Fluid dynamics was all numbers and formulas and regressions of empirical data. This couldn't be even dreamed of back then.
Effin amazing.
Thanks guys for the opportunity to play with it.
Alonso Fan
hi everyone, so after so many months of hardly any free time I have finally come to setup openfoam and mwflow on my tablet
I previously tried to set it up on my pc but something seems to be wrong with the openfoam installation and I cannot get it working with mwflow helper, nor without.
so i'm starting over on a different device (my tablet) and am currently running into a small issue whereby the vm doesn't create a folder with 'my username' in the shared directory. I have named the shared folder c/users and selected a good amount of ram and cpus. I've run OF_Env_Create and also launched openfoam and it seems to be running fine, just no 'my username' folder in the shared directory. I haven't yet tested OF with the test case
i'm posting on here since no one notices anything on the dedicated forum anymore
help is appreciated
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
RicME85
52
Contact:
what tablet are you using? surely that will be dead from trying to run a simulation.
Maybe it doesnt know what your username is.
Alonso Fan
RicME85 wrote:
27 Mar 2017, 00:59
MS Surface Pro 3 core i5 version
it should know my username. docker, virtualbox etc are all in my username folder
still no username folder has appeared in the working directory
SHR Modding
Youtube
Twitter
Discord
rjsa
51
I ran a couple instalations and at some point I had one like this. Afaik it worked just fine - as long as the directory you had set as Shared Directory in the MVRC GUI was the same or under the one set up as the Shared Folder for the VM in Virtualbox.
