Ferrari F138 Model - Alonso Fan
Alonso Fan
Re: Ferrari F138 Model - Alonso Fan
here's the next update guys!
added the white stripe
rear suspension complete
front and rear wing added
all of the decals printed and ready (i started cutting them out, and then i realised that i hadn't taken a picture :) )
after adding the decals, a slight problem... looks like alonso knocked his front wing against the back of a red bull again... and failed the load test by the FIA...
the car fully loaded with decals
clear lacquer
clear lacquer applied to the car... the decals seem to have faded, especially the white ones. i might stick another set on, but do you think it's worth it? (this didn't happen with my sample piece of card, for some reason)
front wing is now fixed, and has a black stripe along the front edge, just like the real one
that's it from me for now, thanks for watching
i'll be back soon with the final update, before the launch of the car
just the tyres to go..
take care
Alonso Fan
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
kosioBG
86
looks great!
i can't say much, except for a couple of questions- what program did you use to get the exact size of the decalls? did you resize each single one? and is the varnish water-based?
can't wait to see how the tires fit on the hubs!
cheers :)
Alonso Fan
For the decals i used Microsoft office word 2007. I got some google images and resized them. (right click on the picture, format picture, then click on the size tab, and enter the dimensions in centimetres. Measure roughly the space the logo will take up on your car first, with a ruler.) then print the decals out and they should be the correct size. I resized the left side decals and then made a copy of them for the right side of the car to save time.
and yes i think the lacquer is water based. I've recently re added the decals again to cover the faded ones. So the car looks a lot better now.
next update will have to wait unfortunately, as i have mock exams coming up.
maybe around 2 weeks time.
until then, take care
thanks foe watching :)
Alonso Fan
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
the long awaited update is here!#
sorry for the really late report
i readded the decals after spraying with lacquer, and the car looks much better now
sorry the pictures are focused on the front of the car, i didn't realise until putting them on
making the tyres
testing on the car
the car at its current stage
i know its taken a long time, but this will be the final update before launch...
expect the launch, with a fully finished ferrari f138 with removable tyres, and removable steering wheel with front and rear jack within the next couple of days, hopefully by the weekend
thanks for watching
take care
Alonso Fan :)
SHR Modding
Youtube
Twitter
Discord
kosioBG
86
I'm glad that this great model will finally be finished.
Question about the tires- from the picture I see you have no wheel yet, i mean, it's just the tire. How are you planning to add it, will you cut out each rim arm?
And some random stuff:
1) what's the length of the car? never thought about that actually
2) you may consider adding the small infor, brembo, magnetti marelli and skp logos on the connection between the floor and the sidepods.
3) are there any front brake ducts? i don't see them at least.
small tip: when printing out logos- on a A4 sheet, there is enough space for two sets of logos. What i did was that i printed each logo twice, with a slight difference in the dimensions and picked the better one right before glueing.
cheers :D
Alonso Fan
kosioBG wrote:I'm glad that this great model will finally be finished.
cheers :D
first of all, thanks for the comment, and naming it a great car
you are correct in the fact that, yes, i have no wheels yet, just the tyres, and I'm afraid it will be staying that way, because the car is way too small to make that level of detail and make it fit properly. I am going to make it look like there is a wheel, similar to my previous car (the Ferrari f10, which was an absolute failure)
another thing other than detail and size is the time. I have very little of it nowadays, and my main objective is to get it finished as soon as possible because i have exams coming up... Again
1) the length of the car is about 31 cm and the width is about 11 cm
2) i did consider adding those logos, but again the size of the car is really tiny, and those logos would be impossible to cut and stick by using my hands (and i have no other method or equipment to do it any other way) and i have quite large hands so that doesn't help
3) yes, there are small front break ducts. They turned out shorter than i expected, and aren't that detailed, but if you look at the last picture i posted, they are in between the front wheel hub and suspension, the bit that sticks out.
thanks for the tip, i will do that on my next car
I'm not sure when I'm going to start it, but my next car should be bigger, longer and wider, and should therefore have much more detail, like proper wheels, more intricate winglets and wheelhubs, more intricate suspension and removable engine cover, front wing, headrest, steering wheel and seat, as well as all the internals, but this one only has removable wheels and steering wheel.
i am currently working on the stickers for the tyres, and the steering wheel.
be ready for the launch in the next couple of days...
take care
Alonso Fan:)
SHR Modding
Youtube
Twitter
Discord
kosioBG
86
31 cm? well, my F14T is 19 cm long, and adding the small logos wasn't a problem. shouldn't be that tricky for you, having a car 1.63 times bigger :?
Alonso Fan
I am visually impaired, so it would be really hard to see for me anyhow. :(
i struggled with cutting out the Pirelli logos on the tyres as well
i will try to but it may delay my launch to tomorrow - i originally planned it for today after doing the last couple of touches like the wooden plank
ah well, we'll see
don't get me wrong though, i will try my best :)
take care, and thanks for the suggestions again
Alonso Fan:)
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
done, brembo infor, skf and other logos printed, and i figured out an easy way to add them to the bottom of the sidepod, so launch either later today or tomorrow guys!
take care
Alonso Fan :)
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
some teasers to wet your appetite :)
full launch later tomorrow hopefully :)
take care
it's getting tense now
Alonso Fan :)
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
And the launch is finally here!
thank you to everyone for giving me suggestions and helping me on my way to making this model
thanks for watching, and that's it from me
take care
Alonso Fan :)
SHR Modding
Youtube
Twitter
Discord
Godius
186
Wonderful, thank you for posting these photo-sets.
Alonso Fan
No problem :), and thanks for the comment
SHR Modding
Youtube
Twitter
Discord
repozess
repozess
Hey !
I've been watching your progress...good work ! [-o<
Repozess
Alonso Fan
repozess wrote:Hey !
Thanks mate!
SHR Modding
Youtube
Twitter
Discord
