Formula 1 CAD model
Post Reply
argi2007
Formula 1 CAD model
Hi guys i'd like to sketch my own F1 car in CATIA V5, but i want some help with the rules. Where can i find a CAD model that shows the rules with boxes or a Formula 1 car model that complies with the rules. I would prefer 2014 model but i dont mind older versions.
Thanks for your help in advance
Blanchimont
214
Re: Formula 1 CAD model
Have a look at the last 15 pages of the 2012 appendix: http://www.motorsport-total.com/f1/Erga ... t-2012.pdf
Now the front wing is narrower, the nose regulations are different and the rear wing/beam wing has changed a bit. But the other dimensions are pretty much the same.
argi2007
Thanks for that.
Any tips on where to start from? What's the best route to design a F1 car in CAD?
Blanchimont
214
I would start with a sheet of paper and a pencil and draw some quick and rough sketches before turning to the computer.
But before you should read through the current regulations (2014 http://www.fia.com/sites/default/files/ ... 1-23_0.pdf
2015 http://www.fia.com/sites/default/files/ ... -06-29.pdf) on bodywork, the survival cell and crash structures.
Do you know what the reference plane, the front wheel center line, the cockpit entry template, the section AA, BB and CC is?
If not google or simply read through scarbs's blog http://scarbsf1.com/ where a lot of these things is explained.
argi2007
Yes i know most of these things except of the cockpit entry template but i'll google it.
Post Reply
