I also think I can beat last year's winner
TF for the first place and you with JJR for the podium are my favourites... but I also hope Variante get back to 2015 performance.
I believe my issue was my mirrors. once I removed the mirrors file from the vehicle_body folder it seems to be working again.etsmc wrote: ↑12 Sep 2017, 08:46so have found the hole in my car and have been running some simulations.
I have added my engine intake and exhaust and also split the mirrors off as a separate STL file in the body folder.
Now when I post process the case I am only getting the following images
InputGeo
InputGeo_wHX
case-004-Cp-tot
case-005-Cp-tot
case-006-Cp-tot
case-010_iso_ptop
Case-021_streams
Case-022_streams
Case-023_streams
Case-024_streams
Case-025_streams
I am missing allot of the others.
I am running a case now with the intake and exhaust excluded and will see how post processing goes on that one.
not looking forward to this race as my efficiency car is not performing as intended and now with people talking of beating last years time, i don't hold out much hope. I may have to run the same car as the last race...
It is a key point for me too. I don't think it is possible to completely control the front tyre squirt. I managed to generate vortices that solve the problem in the front diffuser regions, but the effects on the flow under floor are still present.
Insert >> Object >> Image from PaintAlonso Fan wrote: ↑15 Sep 2017, 11:15Anyone now if there is a way to import a picture into solidworks and sketch over it?
thanks, i'll give that a goCAEdevice wrote: ↑15 Sep 2017, 14:38Insert >> Object >> Image from PaintAlonso Fan wrote: ↑15 Sep 2017, 11:15Anyone now if there is a way to import a picture into solidworks and sketch over it?
... but I always have aspect ratio issues when importing a BMP or JPG.
I did not use the CAESES utility for testing the car. It has been developed with two possible rear wings. The high df setup has a double airfoil wing with a section included in the maximum allowable rectangle (400x150mm). The low df setup has a single airfoil wing included in a rectangle 400x(about)65mm. Both wings were used during 2016 season (the high df section also in Monaco and Nurburgring 2017)
Sorry I was editing the previous answer while tou were writing.
