Tommy Cookers wrote:Fellow enthusiasts !
Please be assured that I am sincere in my basic view, that a normally designed naturally aspirated engine does not have a high enough energy level in its exhaust gas stream to drive a normal turbocharger, (the designer has used the highest possible compression/expansion ratio, and made the expansion stroke (particularly in volume terms) as long as he reasonably can, to extract the maximum energy via the piston). The energy in the gases after the piston's power stroke is dumped as waste.
I still think that my earlier post demonstrates a broad understanding and appreciation of turbocharged engines !
'bye for now
R-1340 Cyclone (aka T.C.)
Tommy Cookers wrote:Please feel free to put forward evidence if you are trying to convince me otherwise !
Tommy cookers wrote: a normally designed naturally aspirated engine does not have a high enough energy level in its exhaust gas stream to drive a normal turbocharger, (the designer has used the highest possible compression/expansion ratio, and made the expansion stroke (particularly in volume terms) as long as he reasonably can, to extract the maximum energy via the piston).
machin wrote:Tommy cookers wrote: a normally designed naturally aspirated engine does not have a high enough energy level in its exhaust gas stream to drive a normal turbocharger, (the designer has used the highest possible compression/expansion ratio, and made the expansion stroke (particularly in volume terms) as long as he reasonably can, to extract the maximum energy via the piston).
I think the point you are missing is that a normally aspirated engine's expansion ratio is limited by the maximum compression ratio that can be achieved without incurring preignition... this means the designer cannot actually achieve his/her desired expansion ratio, and as a result energy is lost as heat out of the exhaust... the turbocharged engine recovers some of this energy, and despite having a lower expansion ratio still manages to extract more useful work from each gallon of fuel as those VW figures show....
To those who understand the technology there was never a misrepresentation. The FiA objective is to save 35% of the fuel use of the V8 engines by introducing technologies like turbocharging, hybrid turbocompounding, direct injection, spray guided combustion and exhaust gas recirculation.Tommy Cookers wrote:Can I again point out that I was complaining about the FIA and some others, not about the turbo, in part my complaint was about misrepresentation of how the turbo works.
The WWII aero engines were predominantly supercharged. Later they used exhaust turbines for turbocompounding 12% of the engine power from the exhaust gas stream. The mechanical compressor and the exhaust turbine were not connected.In WW2 turbos were designed to run with upstream exhaust temperatures of 1725 F, presumably modern ones have a higher temperature capability.
To me this still suggests that turbos run on exhaust gases at higher energy conditions than the unsupercharged car engine generates..
..whatever gases they run on, it's not the energy 'wasted' out of my Hyundai's tailpipe.
Turbos only got into cars (via the competition route with rules much kinder than F1 rules), after 40 years of use in aircraft and diesels, so I'm thinking there was no compelling merit (for cars) then.
They became commercially attractive for homologation of competition winning 'production' cars and as a cheap route to profitable premium cars (cheaper/quicker route to power than building the necessarily bigger/different non-turbo engines). Years earlier fuel injection came in for the same reasons (Merc,Peugeot,Triumph)
Regarding tailpipe emission temperatures of turbo and other engines, do these show up in Rolling Road tests, does anyone have results in this area ?
Regarding the fuel injection developments associated with the 2014 rules, prssumably they are ,in principle, also valuable to designers of naturally aspirated engines ?
They seem able to allow road car engines having the good characteristics of both diesel and petrol engines, I was assuming many would be n/a
The traditional way of having good efficiency in real world use is to choose the engine size that we need, not twice that size. This applies with any type of engine.
Fiat and Ferrari are happy with the new turbo engines except they wanted a high cylinder count for marketing reason. They eventually got the L4 exchanged to the V6 and now they seem to be reasonably happy. Their view is to get rid of the frozen V8s and gain competitive advantages from the new engines.I wonder what FIAT says to the FIA, they have a conflict of interests I think.
Tommy Cookers wrote:In WW2 turbos were designed to run with upstream exhaust temperatures of 1725 F, presumably modern ones have a higher temperature capability. To me this still suggests that turbos run on exhaust gases at higher energy conditions than the unsupercharged car engine generates, whatever gases they run on, it's not the energy 'wasted' out of my Hyundai's tailpipe.
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 4 guests
