Even if they were "given the nod" it is a clear breach of the regulations, and should another team protest the system the Mercedes would be thrown out of the races and, possibly, the championship. Danny Ric for WDC!xpensive wrote:Unless they for some reason were given the nod anyway, wouldn't be the first time, would it now?
I haven't seen any discussion of why this option is written in to the regulations.Blanchimont wrote: So, yes, it is possible to use a clutch to disengage the mguh from the shaft, but the turbine and the compressor have to stay connected all the time.
A clutch is allowed to disconnect the MGUH from the turbo.xpensive wrote:A clutch is allowed by the rules and the difference in speed could be xplained as an unxpected side-effect by the split-turbo.
In the BT46's favour was that the fan did actually draw air through the cooling system.xpensive wrote:Think the Brabham BT46, a cooling-fan that as it happened also generated downforce, it was declared legal even if it was violating the rules on movable aerodynamic devices and only withdrawn voluntarily by MrE for political reasons.
Agreed that is a failure mode for which a clutch would be useful.mrluke wrote:If your mgu-h failed or overheated it would be good to declutch it rather than retire the car due to a turbo that cant rotate.
Incorrect, to Gordon Murray's disappointment, MrE withdrew the car for political reasons to keep his FOCA together, this is well documented. But again, the clutch itself is legal and I believe that MHPE for some obscure reason were given green light by the FIA for the split turbo design even with the mentioned consequence, the latter which was somehow overseen at the time.wuzak wrote: ...
The car was withdrawn because Brabham were told it would be disqualified at the next race.
the short, unequal length headers of the log exhaust don't give an rpm-specific 'free supercharging' element as the tuned system doestoraabe wrote:In term of log exhaust, you are loosing on volume efficiency, but gaining more on turbo efficiency because of shorter piping and higher temperature. So i think that all team will run lo style manifold in 2015. Another big benefit is aero package, and less cooling requirements. The PU106A uses the turbo efficiency better than the other two, and is able to harvest more energy from the MGU-H and power the MGU-K direct.
Could you expand on both of those (sorry its OT)Tommy Cookers wrote: btw amusingly to we oldies the current so-called log exhaust is the opposite of what a log exhaust was
as drifting is now the opposite of what drifting was
I don't believe so. Whether mean exhaust pressure is atmospheric or some other value doesn't reduce the benefit of blowdown energy.Tommy Cookers wrote:a raised mean exhaust pressure would anyway undermine the effect of a tuned length exhaust ?
Just thinking this through in my head. Blowdown energy is energy captured from the kinetic energy of the mass of the exhaust gasses. Usual Kinetic energy formula applies KE = .5*m*v^2.gruntguru wrote:I don't believe so. Whether mean exhaust pressure is atmospheric or some other value doesn't reduce the benefit of blowdown energy.Tommy Cookers wrote:a raised mean exhaust pressure would anyway undermine the effect of a tuned length exhaust ?
trinidefender wrote:Just thinking this through in my head. Blowdown energy is energy captured from the kinetic energy of the mass of the exhaust gasses. Usual Kinetic energy formula applies KE = .5*m*v^2.gruntguru wrote:I don't believe so. Whether mean exhaust pressure is atmospheric or some other value doesn't reduce the benefit of blowdown energy.Tommy Cookers wrote:a raised mean exhaust pressure would anyway undermine the effect of a tuned length exhaust ?
So in the exhaust the mass of gasses is relatively constant throughout each cycle so that is fine. What we can alter is the velocity (v). The velocity of the exhaust gasses is created by the pressure differential in the cylinder vs in the exhaust. The greater the pressure differential, the greater the velocity. The greater the velocity the greater the kinetic energy available to be converted to blowdown energy.
If we increase the exhaust back pressure then we reduce the pressure differential and reduce the speed and hence KE of the exhaust gasses.
Feel free to tell me that I am talking out of my ass but please explain what would actually happen then.
