Craigy
84
Re: Mercedes Power Unit
Mudflap wrote:
27 Mar 2017, 23:45
Both have HQ in Stuttgart and both have powertrain technical centres in Northampton. Have a guess !
Mercedes HPE make their own pistons.
hurril
hurril
Watching the onboard video from Hamilton's pole lap from Australia, I'm struck by a feeling that they don't rev as much as they usually do. Do you guys feel the same way about this? (The instrumentation is surely not to be trusted.)
Do you think this is a case of being kind to the engine this early in the season or could they have altered it somewhat to run more efficiently?
Mr.G
34
hurril wrote:
28 Mar 2017, 11:19
Actually could be both...
63l8qrrfy6
63l8qrrfy6
368
Craigy wrote:
28 Mar 2017, 10:23
Mudflap wrote:
27 Mar 2017, 23:45
Mahle do a lot more than just pistons..
toraabe
toraabe
hurril wrote:
28 Mar 2017, 11:19
Drivers with Mercedes PU106 engines normally shifts at around 11500 rpm. Same as Renault.
Ferrari at 12000 and Honda for some strange reason as late as 12500.
The earlier you can hit maximum power, the more efficient the engine runs.
hurril
hurril
toraabe wrote:
28 Mar 2017, 14:15
hurril wrote:
28 Mar 2017, 11:19
Yeah this is why I asked. I think I observed them shifting even earlier than they usually do for qualifying.
Jejking
Jejking
hurril wrote:
28 Mar 2017, 14:30
toraabe wrote:
28 Mar 2017, 14:15
hurril wrote:
28 Mar 2017, 11:19
Are you sure? What I recall from Australia Q is that Mercedes engines, especially with the Mercs, they were shifting around 12000-12500 for the lower gears, dropping off to 11500 for gears 5-7.
ScrewCaptain27
577
Finally a proper side shot of the 2017 PU, courtesy of AMuS:
- Serj Tankian
Jejking
Jejking
ScrewCaptain27 wrote:
13 Apr 2017, 16:10
https://uploads.tapatalk-cdn.com/201704 ... da083d.jpg
Dayummm.. That's a very sleek, compact design considering all the tech stuffed together.
Edax
Edax
47
I was reading up on some old airplane technology. In the past we had so called "water wagons", airplane engines which used water injection to facilitate takeoff. The way it works is that the water increases the expansion capacity of the air creating more thrust. Great stuff. That technology is now being reconsidered for hot and heavy takeofs for the 777-9.
It just struck me, that that might also work for a turbo piston engine. Indeed I found several past usages of the technology in road going engines where it is claimed to have a significant benefit on power output and engine cooling ( not so for engine wear). I can imagine that a system like that would be relatively easy to hide on an f1 car and you have a few litres of coolant to play with.
would something like that even be possible/beneficial with current F1 engines and could Merc have been using it? I'm thinking of the "uber" mode and the puffs of white smoke we sometimes saw?
I have to admit I am a noob when it comes to piston engine and combustion technology, but I am curious enough to risk exposing my ignorance :wink:
63l8qrrfy6
63l8qrrfy6
368
It does help. It is also banned.
13 Apr 2017, 16:10
The exhaust manifold runners are very long, and the exhaust pipe itself is very interesting, nothing at all like what Mercedes uses.
OO7
OO7
171
godlameroso wrote:
14 Apr 2017, 00:33
The exhaust manifolds are exactly the same as on the Mercedes. The PU manufacturers supply customer teams with the manifolds.
If you meant the exhaust pipe specifically, then yes I agree that they are different, but I haven't noticed anything particularly significant about those differences.
621
[quote=Edax]
It just struck me, that that might also work for a turbo piston engine. Indeed I found several past usages of the technology in road going engines .......[/quote]
aircraft 'WI' was always a mix of methanol and water c.50/50 'Methmix' - the standard (as 100% water would freeze)
some road-use Chevrolet Corvairs had turbos and depended on this
afaik it works in jets etc by its cooling effect, enabling lower AFR (more fuel, more thrust ) which would otherwise exceed safe engine temperatures
of course methanol as a fuel gives more energy per unit air than kerosene or gasoline
btw in a hot and humid region there might anyway be 8% water vapour in the air
afaik Ferrari in turbo F1 used 100% water injection to enable higher boost etc when such was allowed
otoh the evaporative cooling would reduce the compressor work and so increase exhaust recovery or reduce exhaust 'backpressure'
the increased water vapour content in the exhaust could change its specific heat ratio (and maybe at our very high AFR degrade ICE efficiency)
563
In addition 50:50 seems to be the optimum ratio for detonation suppression.
