Intake Valve and Feliks' ideas
Locked
Feliks
Contact:
Re: Intake Valve and Feliks' ideas
:D Gruntguru with this free energy is not so simple as you think .. But then you have some study well .
http://cecelia.physics.indiana.edu/jour ... review.pdf
https://en.wikipedia.org/wiki/Casimir_effect
Here such drivers used in this experience that I had in my apparatus in 1986
http://www.icacommission.org/Proceeding ... /131_1.pdf
Andrew :D
Feliks
Contact:
flynfrog wrote:How much drag does your airfoil have? How much energy are you getting from the fan?
Here you have what is the resistance of about 3 pounds.
Now on the engine blade as well then we will be able to use it theoretically about 30 pounds. and without the teaspoons or even 3 times as much ..
Andrew
Feliks
Contact:
It is nice to finally see how it works in practice my idea, published in 2009
https://www.youtube.com/watch?v=GA_UgVm9bvU
Andrew :D
Feliks
Contact:
And you know what these wings including my project still can be used? not even suppose ...:rolleyes:
This is EXHAUST. .. :p
Thus, the negative pressure is created dam that will serve to suck exhaust gas from the engine .. vacuum will remain on throughout the exhaust pipe .. will suck exhaust lot better than they do, competitive exhaust pipe curled in a "sausage" ...
And by the way a negative pressure can be so great that at some considerable speed, you can turn off the ignition .. :p and cut off the supply of fuel .. :p interesting at what it will speed ..:rolleyes:
and even before up to speed, it also can underpressure to run a turbine from the exhaust and nwtedy that the system does not have to be connected ..
Well, not to mention the alternator, which also would say fueled rotary vane pump on the vacuum ...
Yes, if so, a pair of wings spoon should be at the back of the car ....:D
Andrew :D
Feliks
Contact:
Re: Intake Valve
Feliks wrote:In my latest solving the oscillatory dynamo, a diode who exchanged the changeable oscillatory electricity for the electricity about the permanent polarity was crucial element
Such an element fulfilling identical functions as the diode exists in the hydraulics of theses. There is a valve one-sidedly letting it in to water. it is opening for example only then when the pressure from the feeding side exceeds certain described by the threshold e.g. 10 bars. When the pressure is on the feeding side it is smaller, the valve is closing it oneself. and doesn't allow for moving back waters.
The principles of operation are the same like at pumping the bicycle wheel up with pump, but will refer to water. In this way we can hold. in the pipeline pressure e.g. 10 bars, and from leaking out of the pipeline who will be above the pump e.g. 100 meters will be sailing out water.
The one straight line I decided to use the principle for the production of the electric current with the help of sea waves. Although he is supposed to produce the electricity, it is being imported these are for inflating the problem waters sea into the container with water sea e.g. to height 100 of meters, or similar (e.g. on high cliff seashore). The rest is known and professionally made as the normal power station aqueous, but in this case she will be to sea brine. isn't buying it special one should actually solve the difference, only a matter of the precipitated corrosion .
Particularly that such a very similar solution was already on an island applied Okinawa, in the version of the power station pumped storage (but pumping into the container with the help of the electric energy- classic pumped storage).
Into my to pump the version this brine there will be sea waves driving water pumps with valves with diodes into the container Leaking in water only in direction of the container. pipes from pumps into the container will also have middle diameter, in order to in the time of whom from valves, not to waste the energy from different good pumps. Unfortunately the number can reach such pipes even 1000, at the productivity every e.g. 1 m^ 3 / sec.
But by it we can get the power of such a power station 1000 of the MW .
Costs of making such a power station will also be smaller, since for her devices won't have to pump water into the container how it is in classical power stations of this type. Machines will be so like by a normal hydroelectric power plant straight lines and no high cost.
http://www.new4stroke.com/salt%20water% ... torage.pdf
http://www.new4stroke.com/Okinawa.jpg
Also shortened descriptions Polish pumped - storage to slight differences of the water levels (100 m) is describing http://www.pistonheads.com/gassing/topi ... 7463&i=260 or
http://www.new4stroke.com/plants.pdf
Gross from many centuries of coasts England and Ireland they were attacked by marine waves .
People built obstacle for these waves sometimes, that they did not prevent from life on islands.
I think that would end this immemorial war goods , and invite this ocean on coast, but that it is high, it belongs it help. It belongs to take advantage it waves, in order to they pumped on its high coast of water.
I think, so around England , Ireland , North America ,shall made this power plant.
More belongs to place in ocean for water pomp e.g.
Pistons type , or my idea half rotate, which will drive usual floats clinched for they behind assistance of rope. Ordinary belongs to place behind each pump bolts, which will be opened e.g. at 10 kG/cm2 (Acting similar for diode I my oscillating dynamo) and which for collect tubes for reservoir on high coast miss water drive it.
Collecting tube should for example for flow 1 m3/sec 0,6 m have diameter.
http://www.new4stroke.com/aaa4t.gif
http://www.new4stroke.com/pompa11.gif
http://www.new4stroke.com/storage.JPG
For achievement in such this collecting tube of flow 1 m3/sec and 10 bar , requirement 12 pump wanted for transport water on according to following specification 100 m height too reservoir.
Pump reconciles, for simplification about normal piston, should have 0,6 m diameter, and 3 m of height. During average jump of rippling 2 m, it will give during one cycle for composite tube 0,5 m3 water pushed (S= 28 dcm2 H= 20 dcm (2 meter) = 560 dcm3 (liter). For set up flow 1 m3, TWO such pumps should pump for collecting tube.
For proper fabrication of pressure on exit of pump ( set up 10 bar ), wanted proper swimmer is.
There is simple account surface of piston of pump will together page (S) x 100 surface of swimmer.
In my example, surface of piston of pump it 28 dcm2, it signifies that swimmer)should have 2800 dcm2. In order to swimmer had such surfaces, it must have 20 m diameter, and definitely 1 m of height. It needs one kit about 12 pumps 12 swimmers 20 m each diameter, or about dimension one swimmer 12 x28 m2= 336 m2.
For behavior some reasonable spans, it is possible to accept, that for such array for production capacity 1 m3/sec 10 bar, wanted near 700 m2 place rippling sea .
Need for continuous supplying tank for power station theoretically 700 m3/s (716 MW , 100 m height ) requirement 700 x 700m2 = 490000 m2 rippling sea . It is theoretically only 700 m x 700 m !, when 2 m average heights of waves.
Here, mathematical enumeration same only:
To 1m3/ sec
1 m^3/sec 10 bar(H=100m ), 600 mm diameter pipe and piston pump, S= 28 dcm2 Hwave= 20 dcm (2 meter) = 560 dcm3 (litre) for 1 m3 need 2 piece . but period are 6 sec , sum 6x 2 = 12 piece pump .
S pump= 28 dcm2 , 10 bar, F =28 T, Hfloat >1m, S float ~~=2800 dcm2 (28 m2) , D float =~~20m
12 piece x28m2 =336 m2 ~~ =100m x 7m using area =700 m2
700 MW (700 m3/sec), H=100m
700 m2 x 700 = 350000 m2 . ~~700m x 700m area of wave
As elements are presented from marine waves over system production current professional , they are built in the world already and test, additional requirement of experience for their building not.
Another, very important information in relation to the system. System the one should be only as storage, rather than storage-pumped what significantly the height of investments will lower in comparing to current answers. Costs will only be so like for an ordinary hydroelectric power plant
Only water pumps with valves (diode) can so that touch up still and selected materials. but in general, it is piston pump known for the antiquity. Summing up, mechanical problems are solved, and with the appropriate swing one should only build such a power station.
The degree of the safety of such containers will also be very high, since put very close the sea, in case of the breakdown of unsealing, they won't cause heavy losses, since water quickly will find its way back to the sea.
I think that wonderful geographical conditions will permit on high cliff Scotland England and Ireland, to build such containers into whom sea, highest waves will be pumping brine on average in world a lot. it means that the efficiency of such a system will be most effective in world, and therefore built containers should be around these countries what in the future can guarantee the green energy for all countries Europium.
Regards Andrew :D
Some patents as their own, others omit,, But the most beautiful prototype from Berkeley:rolleyes:
https://www.youtube.com/watch?v=fYfs-qY ... e=youtu.be
https://www.youtube.com/watch?v=gZFM0gh ... e=youtu.be
Andrew :D
Feliks
Contact:
So now even a version
So here the animation ramjet engines between the wings in a spoon effect, which is about 9 times increase input speed .. Pipes of course without turbines, such as SR 71, and, so to eye with 250 MW of getting So, yes, the set of a diameter of 30 meters, having the 250 MW of power, he would have 12 pieces of such pipes since SR71, visible starter pneumatic boot, and the number 2 units would give so much energy around, a small nuclear power plant Only with the size of the power plant, even coal, consumed for own use 50 MW (high pressure pumps, blowers and fans, etc.). Here only the minimum energy for the fuel supply system, expressed in kilowatts ..
And the cost of investment that air football field, probably will be significantly smaller.
It's to improve the imagination, what I'm saying.
Well, here we have any fuel - coal dust, gas, oil.
https://www.youtube.com/watch?v=8u7dzn7 ... e=youtu.be
Andrew :D
Feliks
Contact:
Wuzak, on 12 Oct 2015 - 03:07, said:
The SR-71 had turbojets, not ramjets.
So yes, engines SR71, a combined cycle engines .. to take-off and less than one Mach a turbine engine plays an essential role, but above the speed second element of this combination, which is a ram-jet engine (the tube that flows air) begins to play a dominant role speeds above Mach 3, giving it 82% of the total during what has at its disposal the plane. that is, if we gave up at that speed at all of the turbine engine, this string would only decreased by 18%. I think that on threads loss in our application we can afford and get rid of at all of this very complicated and expensive engine components SR 71. we are left only ram-jet, and he will be with an efficiency of about 95% at the speed .This is written in the NASA study concerning the second combined cycle Ramjet engine of the rocket engine .. rocket engine ..
https://en.wikipedia.org/wiki/File:SR71 ... tterns.svg
http://www.nowy4suw.republika.pl/sr71%20naped.pdf
http://ntrs.nasa.gov/archive/nasa/casi. ... 013567.pdf
https://smartech.gatech.edu/bitstream/h ... 6-2688.pdf
But for our purposes of energy production should be enough speed less than 1 mach. Well, here the helicopter, which must be produced from 100KW power to fly ..
https://www.youtube.com/watch?v=evjd49r ... e=youtu.be
Except that I would not advise that a helicopter to fly .. but the current can do safely :rolleyes:
Andrew
Feliks
Contact:
So come on ramjet engine, such as the SR 71 .. which drives the generator on a treadmill, and give you the energy ... but when we have a stream of departing gases, after the addition of neodymium magnets can be good even with these tubes directly receive electrical energy generated MHD generator .. no as shown in the figure also how we will burn pulverized coal .. no but the engine is a framework is the same as scram jet, only at lower speeds. In 2015 Tokyo was developed in the engine scram is that with the help produced on the basis of MHD power also speeds up the exhaust gases on the MHD reverse. We need to get all our MHD mounted on the framework jet engine gave only electricity .. extra for electricity from the generator to the axis of the device .. but that's not all we can with the energy produced in this way receive .. Because the device is going to rotate in a circle with a diameter of 30 m, then we can all thermal energy from the combustion of fuel to pick up, building a 35-meter housing for the device. And WHOLE heat generated can pick up with the aid of heat recovery units (coolers or tubes such as in a steam boiler) and use it, or even to produce additional power, or (i) for heating .. This time none have not wasted :mrgreen:
Andrew :D
Feliks
Contact:
Here the newest model of the wind my car .. Only cosmetic changes on the outside .. :)
But inside the revolution ..
I present two screenshots of the simulator NASA airfoil and it is clear that at different angle of attack with a symmetrical profile, receive different values ​​of lift .. From negative to positive .. or 160 KG positive, or 160 kg (320 lbs) negative (downward pushing sash) when changing the angle of attack of 30 degrees .. and dimensions of the wings 2, 5 meters square at a speed of 100 km / h (60 miles)
Well, this wing of their forces can drive the crankshaft directly ..
Here, the animation .. The angle of attack of the wing can change either electrically or mechanically (cam) There is no need for this high energy ..
https://youtu.be/evC5y0wgOVM
Well needless to say that such a system also can work at creating their own wind ... ..
I had to publish it on Santa Claus, but that the climate summit a little hurried me .. Because after what happened there in May too tired and negotiate, as you no longer need .. maybe someone out there will send a telegram?:rolleyes:
Andrew :D
Feliks
Contact:
This year, with best wishes for Christmas to all something more pleasant ..
I designed a completely new an amplifier for guitarists. Of course, for lamps, but with a completely has not used elements .. I made a prototype amplifier. Well, I think that I managed to get fairly good sound. An amplifier is built on 4 x EL34 and attached to the speaker box with two Celestion G12M .Here movie, from a small club (30 persons) in Krakow, where my friend Leszek playing for the first time in my amplifier. After a concert gave very positive opinions about the brand new, my tube amp design .. Was this opinion was correct, can you assess yourself listening as playing solo on the film of this show ... :)
https://youtu.be/JncURyq77sM
[youtube]JncURyq77sM[/youtube]
And here the Silent Nigt with Christmas wishes for all ...
https://www.youtube.com/watch?v=w_PfwVNmckc
[youtube]v=w_PfwVNmckc[/youtube]
Andrew
Feliks
Contact:
Well, maybe you need to start from the simple structure ... Here a tandem bike in which the other in the rear never laze will not be ....
The experience you need to slowly gather .. the Wright brothers' first flight at the time, only 278 meters flew his machine ..
Andrew :D
Feliks
Contact:
Here is clear evidence that that there are amplifiers, which are able to significantly strengthen, without any additional energy absorbed from the outside ...
https://www.facebook.com/LaMusique/vide ... 333573937/
Andrew :D
J.A.W.
109
"...Significantly strengthen..."
What, exactly F-?
Noise level?
Perhaps if you can demonstrate your - so far - endless iterations of seemingly Lewis Carroll-type 'impossible ideas'..
..via a pulse-jet running solely on atmospheric air, & sans energy waves propagated from a fuel source..
..then from what appear to be fanciful variations - on the 'perpetual motion machine' theme - you could win a Nobel Prize..
Tip: ( Try a search of the FBI's collection of ex-Kammler/Tesla papers, some of which may be declassified by now).
Feliks
Contact:
Well, sometimes you can use the models made by others, and do not spend money on their models. Here you can see very well that this model boats, capable of flowing even into the wind .. But demonstrator, not even suppose that, in this way, is also a way to produce wind, because the boat is sailing faster and for this reason, the wind acting on the windmill you will be getting stronger ... if you are a boat tied to a string to floating around, it will float forever ... .. unless my eyes deceive me .. :roll: .. of course my solution, instead of the classic windmill, windmill will be Red Baron version double teaspoon, which closed Roots and the propeller will power.
https://www.youtube.com/watch?feature=p ... Rw_qJytbG8
Andrew :D
Locked
