F1 Steering Wheel electrical connections
Post Thu Apr 01, 2010 6:50 pm
I'm quite intrigued about something to do with modern F1 Steering wheels. There is a multitude of buttons, lights, screens on today's F1 steering wheels, but how are they connected electrically with the car? We see steering wheels "clipped" onto the cars, and popped off when drivers want to get out of the car. Does anyone know how the electrical connection is made from the steering wheel to the car? Could it possibly be a radio connection, or is there some type of ring(s) on the steering wheel shaft with brushes making contact from the stationary chassis side?
If anybody could shed some light on this it would be greatly appreciated!
Reason: edited title to reflect topic
Rhino
Post Thu Apr 01, 2010 7:10 pm
Couple ways of doing it on motorsport steering wheels I've seen.
Easy way is to just have a coiled cable that plugs into both the side / back of the wheel, and to the chassis.
The 'cleaner' way is to just have an electrical pass-thru on the quick-release hub. The spline makes sure all the pins are lined up correctly when you slide the thing on.
Grip is a four letter word.
2 is the new #1.
Jersey Tom
Post Thu Apr 01, 2010 7:13 pm
Take into account that you basically only need two terminals (which makes things quite simple). Both the power supply as well as a variety of data channels can run through those two lines (for examples, you could take a look at Profibus-PA systems).
spacer
Post Fri Apr 02, 2010 6:51 am
Thanks for the replies. Serial communication makes sense and keeps things very simple.
Rhino
Post Fri Apr 02, 2010 6:10 pm
Rhino wrote:Thanks for the replies. Serial communication makes sense and keeps things very simple.
SECU use CAN links for in car communication. Then various sensors are connected through Sensor Interface Units (SIU), Sensor Nodes (SN), CAN Interface Units (CIN), Hub Interface Units (HIU) and so on which relay the communication to the main control unit through the CAN bus.
Edis
Post Sun Apr 04, 2010 8:30 pm
spacer wrote:Take into account that you basically only need two terminals (which makes things quite simple). Both the power supply as well as a variety of data channels can run through those two lines (for examples, you could take a look at Profibus-PA systems).
The only problem with this is that the dash has data inputs (read to the display), controller switch out puts, and ECU outputs to change mapping selections. Need more than two pins to do this.
Almost all F1 dashes uses electrical connectors built into the quick release with 8 pins and up....like this one
http://www.hrpworld.com/index.cfm?tpc=S ... on=product
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
speedsense
Post Mon Apr 05, 2010 4:15 pm
You can use an interface unit to convert these signals to bus communication, then you can do it with as little as four wires. Two for power and two for the CAN bus.
There is usually a built in mil-spec connector in the steering column, yes.
The dash, a McLaren PCU-6D, is in some cases built into the monocoque and in other cases built into the steering wheel.
Edis
Post Tue Apr 06, 2010 5:41 am
Yet to see anything less than an eight pin connector. CAN included. Too many things that require priority to get "packaged" into a CAN queue. The shifter paddles sensors being one of them, for example.
speedsense
Post Tue Feb 14, 2012 8:39 pm
If they're using multiplexing two wires would be enough.
Come back 747, we miss you!!
Caito
Post Tue Feb 14, 2012 8:57 pm
Maybe there is some pin usage redundancies. It is a very active connector and probably has a small amount of movement when engaged.
Brian
hardingfv32
Post Thu Feb 16, 2012 11:06 am
Caito wrote:If they're using multiplexing two wires would be enough.
Yeah,i think so.it is enough.Image
piperurhy
Post Sun Feb 19, 2012 11:40 pm
Edis has it right (or should I say ´had´ this is an OLD thread). The switches and paddle inputs are all passed to the ECU over CAN. The display is controlled either by a serial interface or CAN depending on the display type (the older 6C unit uses serial)
See
http://www.mclarenelectronics.com/Produ ... uct/PCU-6D
and
http://www.mclarenelectronics.com/Produ ... ct/SIU-300
As for the connectors, Souriau, in particular the 8STA -518 range, are pretty much standard for steering wheels
pitlaneimmigrant
Post Sun Feb 19, 2012 11:57 pm
The 8STA -518 does not look like it has pins and sockets, just pads. Is this a correct observation. I have never seen such a connector before in the defense industry. Could this be a special application type plug?
Brian
hardingfv32
Post Wed Feb 22, 2012 1:02 am
Take a look at http://www.souriau.com/motorsport/repos ... System.pdf, I can assure you they are used in F1.
This style of connector is based on other Souriau/Deutsch motorsport connectors which in turn are based on Mil-Spec systems such as MIL-DTL-D38999, but in this instance are a special application (removable steering wheels probably don´t get used a lot outside of motorsport)
The pictures in the brochure don´t show the pins in the connectors which makes it look they they have pads, but the connector half which goes in the wheel would be populated with pins
pitlaneimmigrant
Post Wed Feb 22, 2012 6:22 pm
Usually two copper contacts or "slip rings". One being ground the other being usually 12v.
Data is passed through the DC lines digitally. They'll probably eventually become radio connected, if not already :wink:
Agerasia
Next
Return to Engine, transmission and controls
Who is online
Users browsing this forum: Baidu [Spider], CCBot [Bot], Exabot [Bot] and 6 guests
