Interesting scarbs, funny there is no ban on DLC, would you have any idea what the oppsite surface in the liner could be?scarbs wrote:Yes JA is getting a little confused there. Last week about a dozen journos were taken on a tour of the Mercedes AMG powertrain factory (what was MBHPE). I was amongst that group.
We were shown a range of F1 engine parts, including a current V8 piston. It was totally coated in DLC, which along with the raduissed edges may have appeared to be ceramic. But obviously not, as the rules demand alu pistons.
It is indeed, often used as coating on balls, rollers and raceways for bearings, in order to reduce wear and friction.Dragonfly wrote:A bit dumb question:
DLC - is this for Diamond Like Carbon?
To be precise was the interior and piston crown also coated with DLC? What was the general color and was it uniform over the complete piston. Was DLC stated as the coating by company reps?scarbs wrote:We were shown a range of F1 engine parts, including a current V8 piston. It was totally coated in DLC, which along with the raduissed edges may have appeared to be ceramic.
1) Although things do change, nickel/silicon carbide composite coatings (ceramic) were/are generally the best solution for the bore coatings. Have you heard of anything better being developed?xpensive wrote:Interesting scarbs, funny there is no ban on DLC, would you have any idea what the oppsite surface in the liner could be?
No, just any knowledge he feels he can make public. This is stuff the average racer has access to these days IF he knows what to ask for.xpensive wrote:You want fries with that...Brian?
That's how oil collecting rings are usually constructed.scarbs wrote: Firstly a pair of thin (stainless steel?) rings with a corrugated inner ring ...............
