Both points are facts not opinion.xpensive wrote:I still beg to differ.Facts Only wrote: ...
A roller clutch is not legal, the compressor and turbine must rotate at the same speed at all times, there is no loophole.
The FIA have design data and a homologated engine to compare it to, they can also compare this engine to any engine during the season to confirm they are still legal.
This may be correct, and you may even be Bob Bell for all we know, but just saying they are facts without any verification isn't confidence inspiring.Facts Only wrote:Both points are facts not opinion.xpensive wrote:I still beg to differ.Facts Only wrote: ...
My *guess* is that Ferrari hasn't fully mastered the MGU-H and is venting pressure at partial throttle.Why does the Ferrari engine sound so different to others? Quite often with partial throttle in corners the engine sound modulates a lot. Renault and Mercedes usually sound smooth with partial throttle / mid corner.
What do you know?gruntguru wrote:The amount of energy "available" in the exhaust has nothing to do with turbine design. The main factors are mass flow, temperature and pressure (including pressure transients ie "blowdown"). The pressure can be adjusted by turbine selection to increase or decrease the power available by as Tommy said this will affect the ICE power. Turbine design will increase or reduce the efficiency ie how much of the available exhaust energy is converted to work. (Note that all the available energy can NEVER be converted to work.)
Turbine design and selection is NOT a factor in MB's power advantage. Every team has a turbine selected to match their engine design and strategy.
Turbine design and efficiency has well established technological boundaries. The chance that there is even 1% difference between teams is remote.
If MB has a "bigger" turbine, that is a result of some difference in their engine design or strategy.
Enough.ringo wrote:What do you know?gruntguru wrote:The amount of energy "available" in the exhaust has nothing to do with turbine design. The main factors are mass flow, temperature and pressure (including pressure transients ie "blowdown"). The pressure can be adjusted by turbine selection to increase or decrease the power available by as Tommy said this will affect the ICE power. Turbine design will increase or reduce the efficiency ie how much of the available exhaust energy is converted to work. (Note that all the available energy can NEVER be converted to work.)
As little as you do? ie less than I currently do?Show some theory.
That is easy to check.In case you're new to the site
The word "NEVER" (caps BTW not bolded) emphasises a thermodynamic fact.i don't prescribe much to semantics and bolded words.
1% is what I would consider an upper limit to the difference in turbine isentropic efficiency from one team to another.in fact i don't see where 1% came from and if it has any bearing on anything, what is that?
Yes. I am not a turbine designer but I understand the principles of turbine design. Seriously.Are you familiar with turbine design? on a serious note.
This makes a whole lotta sense grunts, thanks.gruntguru wrote:The amount of energy "available" in the exhaust has nothing to do with turbine design. The main factors are mass flow, temperature and pressure (including pressure transients ie "blowdown").
I am not Bob Bell.Cold Fussion wrote:This may be correct, and you may even be Bob Bell for all we know, but just saying they are facts without any verification isn't confidence inspiring.Facts Only wrote:Both points are facts not opinion.xpensive wrote:I still beg to differ.
You are the one making claims, i'm simply asking to see some supporting evidence. I would like to know why you believe that a turbine's design has nothing to do with how much power it can extract.gruntguru wrote: As little as you do? ie less than I currently do?
Why would you suggest that?1% is what I would consider an upper limit to the difference in turbine isentropic efficiency from one team to another.
There is more to it. I don't know it all about turbines but I know what is involved in designing blades for a certain flow. And Mercedes can have some kind of novel approach with their turbine.Yes. I am not a turbine designer but I understand the principles of turbine design.
ringo wrote:I would like to know why you believe that a turbine's design has nothing to do with how much power it can extract.
That is a very serious claim that you are making there.There is more to it. I don't know it all about turbines but I know what is involved in designing blades for a certain flow. And Mercedes can have some kind of novel approach with their turbine.What I actually claimed was:
1. The energy available is a function of the ICE.
2. The % of that energy actually recovered is a function of turbine efficiency.
3. Turbine efficiency has a pretty solid ceiling these days after centuries of development. Finding a 1% advantage would be very unlikely.As I said. Very unlikely. The multi billion dollar turbine industries (GT, Jet engine, steam turbines, Turbochargers etc) would have discovered it by now. They have much bigger budgets and much more to gain from even the smallest gain - let alone a breakthrough.
Thanks for this Facts Only.Facts Only wrote:People making ascertations that a manufacturer is using a system which is A) Not legal and B) Of no actual use anyway if you properly understand the system isn't confidence inspiring either.
But Rule Recap, this is how everyone in the actual business and TWG reads it:
5.1.6 (deleted for space)The shaft must be designed so as to ensure that the shaft assembly, the compressor and the turbine always rotate about a common axis and at the same angular velocity, an electrical motor generator (MGU-H) may be directly coupled to it.
This dentoes that however the Turbo is layed out the basic Compressor/Turbine assembly must be on a common axis with all parts always rotating at the same speed irrespective of what the MGUH is doing or how many parts are in the system. Thus even with a split turbo with separate shafts for the Comp/Turbine the coupling or link shaft must be a direct fixed link on the same axis. Any sort of clutching, overspeeding or gearing is not allowed
5.2.4 The MGU-H must be solely mechanically linked to the exhaust turbine of a pressure charging system. This mechanical link must be of fixed speed ratio to the exhaust turbine and may be clutched.
This rule actually confirms rule 5.1.6 as it separates the Comp/Turbine arrangment in the rules and leaves no ambiguity for interpretation of parts running on the same axis and at the same speed no matter how you interface the MGUH. The MGUH can be either on the same shaft or running coaxially using a link with a ratio other than 1:1 but it must remain constant (i.e Fixed gear). A cutch may be added to this link. What you cannot do is put the MGUH in the middle of the Comp/Turbine and then use that as an excuse to separate the Comp/Turbine shaft assembly and so break rule 5.1.6. This is completely unambiguous.
5.2.5 Cars must be fitted with homologated sensors which provide all necessary signals to the FIA data logger in order to verify the requirements above are being respected.
I have not seen this rule quoted in this thread (perhaps conveniently for some) but it is the final nail in the coffin for the theory, there is a speed sensor on the Compressor Side, Turbine Side and MGUH to confirm the angular velocity that none of the rules above are being broken.
With regards to the usefulness (or not) of the clutch in the theory I will perhaps get onto this when I have another few spare minutes.
