As far as I calculated they are traction limited up to at least 200km/h.
I observed the drivers activate KERS above this speed so I rate the result as approved.
See Sauber's wheel as an example.. They have a dial - KERS Release Map - on the right, with at least 12 different output maps to utilise KERS.Fil wrote:1) KERS output can be adjusted by the driver. The steering wheels have dials specifically for this purpose.
For the avoidance of doubt there has never been an FIA rule about a min speed for KERS. However, there are laws of physics that use of KERS at slow speeds is a less effective use of the available energy than at higher speeds.010010011010 wrote:Im have also heard that kers cannot be used under 100km/h, but cant find a source. Maybe the rule has changed?
I also have never seen that rule. More to the point, how exactly would it make "the perfect launch system"? As it presently works that is. You launch with 80hp, which is clearly not enough to do anything, so you're still forced to get the vast majority of your launch torque from the engine. You want desperately to get out of the transient range of your engine, and using kers at launch will just keep you in it longer. And once you are no longer traction limited and can make use of unlimited power, you can't use your kers for extra power because you've already used it all up.Just_a_fan wrote:As for KERS off the line, no, the rules don't allow it below 100kph off the line, presumably for this very reason - it would be the perfect launch system.
That is incorrect, as noted several times already on this thread.Pingguest wrote:As far as I know, drivers can't use KERS until 100 km/h, because the SECU disables it.
Its diffrent KERS maps i belive. There are 4 diffrent KERS maps, each for diffrent purposes, there is a start map that has 3 diffrent power settings a tire phase 1 map that also have 3 diffrent settings and phase 2 setting as well with 3 diffrent power settings, and a wet weather setting whitch has 2 settings and a pits setting, whitch is effectivly putting the KERS into charge only mode for the in lap before a pit stop, it also puts the KERS system into retardation as well. Ferarri also have a 2 way SPDT toggle switch that puts KERS off.mep wrote:Maybe there was a rule during 2009.
I can remember of something like this during that time.
Btw: I really wonder why the Sauber steering wheel has 12 possible adjustments for KERS alone. Any idea's what they are for?
