DTM 2012
Post Mon Sep 26, 2011 12:29 pm
Anyone knows if there is anything on 2012 regulations of a mandatory to use only 2 door coupe chassis or is legible too still 4 udoor saloons chassis!
GutZ
Post Mon Sep 26, 2011 1:12 pm
I thought the frame itself was a mandated section that is supplied to the teams no?
失败者找理由,成功者找方法
raymondu999
105
Post Mon Sep 26, 2011 1:53 pm
I´m trying to get the 2012 regulations for weeks.
Even in 2011 you would have been allowed to use 2 door cars. So I think this is an agreement between the manufacturers to use 4 door or 2 door cars respectively.
AFAIK only the monocoque is a standard part.
matt21
Post Tue Sep 27, 2011 12:38 pm
So there is no way possible to find 2012 dtm regulatios released dtm responsables?
GutZ
Post Wed Sep 28, 2011 8:10 am
Up to now, I didn´t find anything.
The governing body is the DMSB, but they released nothing.
matt21
Post Wed Sep 28, 2011 8:31 am
I think it should be just a matter of time. After all they do release the 2011 DTM tech/sporting regs
失败者找理由,成功者找方法
raymondu999
105
Post Thu Sep 29, 2011 11:02 am
I realy hope so, i wana to build the 2012 dtm season for rfactor and i need the corect regulations tomodel the cars and phiscs under.
GutZ
Post Sun Oct 02, 2011 2:37 pm
slightly off topic, but so. Tomczyk is the reigning world champion; but we're ending this season with an Esktrom that's massively on form; with 3 wins and a 2nd place out of the last 4 races (sound familiar?)
失败者找理由,成功者找方法
raymondu999
105
Post Mon Oct 10, 2011 1:17 pm
Im not a aerodimamics guy so i was woundering if some one can clear me out the reason for the swan neck rear wing suports unsted the normal vertical suports!
GutZ
Post Mon Oct 10, 2011 2:00 pm
the regular supports create flow seperation on the underside of the wing, the swan necks do not
Post Mon Oct 10, 2011 3:02 pm
wesley123 wrote:the regular supports create flow seperation on the underside of the wing, the swan necks do not
Thanks for the reply, so the reason is technical, on the other way is just me or the swan neck system make the car very very ugly!
GutZ
Post Mon Oct 10, 2011 8:12 pm
Other question i have desire to discuss here if you guys have the kindness to reply is the overal width of the cars, 2011 regulations alow the maximum width of 1950 mm, this rule will be the same for 2012 regulations so i made my calculations and having a base car with 1821 mm like the bmw m3, substracting the 1821 from 1950 the result is 129 mm wider, this number divided by 2 is something like 65 mm for each side, my question is dtm cars just have 6,5 cm of wider wheel arch? or they look wider in my eyes or there is some numbers or calculations that i dont know about! please coment!
GutZ
Post Tue Oct 11, 2011 7:33 am
As far as I know, the cars will be wider.
But as mentioned above, the regulations are not released yet.
BTW: The width for 2011 is 1850mm without mirrors.
matt21
Post Tue Oct 11, 2011 8:08 pm
matt21 wrote:As far as I know, the cars will be wider.
No not realy true, 2011 regulations sets the max wider of the cars without mirrors in 1950 mm and not 1850 mm and the next year cars where build with this width but things can change easy, there still is pleanty of time till next year first round!
GutZ
Post Wed Oct 12, 2011 2:36 pm
GutZ wrote:No not realy true, 2011 regulations sets the max wider of the cars without mirrors in 1950 mm and not 1850 mm
Where do you have this info from?
DMSB wrote:Article 5.1.5: The bodywork width of the car without homologated external view mirrors must not exceed 1850 mm.
http://www.dmsb.de/downloads/472/2011_D ... ations.pdf
matt21
PreviousNext
Return to Other racing series
Who is online
Users browsing this forum: No registered users and 4 guests
