gato azul wrote:I thought, one of main ideas about the shark fin, apart from helping with directional stability (yaw), to prevent a spin,
was that in case of an spin and a car going sideways at high speed, it will create a high pressure area on top of the whole
area of the bodywork in front of the shark fin, thereby making it more difficult for the car to "lift off".
In a similar fashion like a "air dam" or "rear deck spoiler" would work.
One could argue, that in this case, and other similar accidents, the new floor rules, demanding the floor to rise from the
centre towards the outside, are detrimental, by allowing more air to pass under the floor from the sides.
gato azul wrote:I thought, one of main ideas about the shark fin, apart from helping with directional stability (yaw), to prevent a spin, was that in case of an spin and a car going sideways at high speed, it will create a high pressure area on top of the whole area of the bodywork in front of the shark fin, thereby making it more difficult for the car to "lift off".
RacingManiac wrote:The Toyota also lost its rear wheel after the initial hit from the Ferrari, so the car is already sitting with its nose up on the right side as it starts to spin, probably letting more air underneath the car than it otherwise would have...
bhallg2k wrote:Instead, the shark fin might have actually accelerated the yaw. That's the issue here.
At 90° yaw the fin has a big effect on the rolling moment that starts the roll.
skgoa wrote:No matter what speed, a fin that low would not have flipped a car that wide on its own. Even if that notion weren't idiotic, we would have to wonder why none of the spins that weren't induced by a Ferrari have led to flips. At that speed even a little air under the floor can make an LMP car tumble through the air.
bhallg2k wrote:skgoa wrote:No matter what speed, a fin that low would not have flipped a car that wide on its own. Even if that notion weren't idiotic, we would have to wonder why none of the spins that weren't induced by a Ferrari have led to flips. At that speed even a little air under the floor can make an LMP car tumble through the air.
Thank you for your inattention.
Users browsing this forum: CCBot [Bot] and 2 guests
