WEC (World Endurance Championship) 2014
WhiteBlue
92
Contact:
Re: WEC (World Endurance Championship) 2014
djos wrote:If Audio want to put big fat heavy tractor motors in their cars that's their problem. Those using real car engines shouldn't be penalized for someone else's stupid decision!
This is obviously an off topic comment. The WEC wants high efficiency technologies like turbodiesel to be run. This will only happen if the promoters of such technologies are not disadvantaged.
djos
113
Contact:
Diesel's might efficient but there's nothing "green" about them, their carcinogenic fine particle pollution is actually far more toxic (proven to cause cancer) than the gasses emitted by petrol engines.
"In downforce we trust"
WaikeCU
How does LPG compare with diesel? I hear LPG is cleaner than petrol or diesel, but what about performance wise?
WhiteBlue
92
Contact:
djos wrote:Diesel's might efficient but there's nothing "green" about them, their carcinogenic fine particle pollution is actually far more toxic (proven to cause cancer) than the gasses emitted by petrol engines.
Diesel particle filters are state of the art and push the toxic dust level down to other types of fuel. This is a pseudo problem which the industry has long solved.
WhiteBlue
92
Contact:
LPG is a good way to drive clean particularly in bi fuel applications where diesel is used to ignite the gas. The problem is the gas storage in the car which is heavy and space consuming and the infra structure or lack of it.
langwadt
afaiu some research show that while the filters remove most particles they leave behind the ultra fine particles generated
with modern high pressure injection and those are the most dangerous because like asbestos they can get deeper into
the lungs
WhiteBlue
92
Contact:
is this urban myth or scientific truth? perhaps you have a source which would make a fair comparison with other environmental risks of other fuels. I'm thinking of cancer generating toluene and other dangerous compounds in high powered petrol.
mike
the lungs
Diesel filters are very efficiency these days even with finer particles are high pressure systems
regulations are defined with how many particles emitted rather than weight, modern GDI has the same issue due to reduced time to mix and does not have a particle filter at all, so diesels might not be "green" but its definitely "greener"
Cam
45
Arstechnica wrote: 1000-horsepower technology-packed hybrid race cars take the pole in 2014
We've got the skinny on the tech you'll see on the track—and why racing is awesome.
A really nice article by Arstechnica, looking at F1, WEC and Indy Car - with comparisons, technical info and photos. It's nice to see a 'tech mag' have a look at racing and call out the 'pro's' - heavens knows F1 needs all the media help it can get right now.
― Socrates
djos
113
Contact:
Sorry mate but that simply isn't true, the particulate filters are only 95% effective.
djos
113
Contact:
WhiteBlue wrote:LPG is a good way to drive clean particularly in bi fuel applications where diesel is used to ignite the gas. The problem is the gas storage in the car which is heavy and space consuming and the infra structure or lack of it.
Not to mention the 30% lower energy content per kilo compared with Petrol.
Lycoming
106
Got a source for that number, or should we just take your word for it?
djos
113
Contact:
Not my word at all:
http://energy.gov/sites/prod/files/2014 ... _parks.pdf
http://www.aqmd.gov/docs/default-source ... f?sfvrsn=2
Even Euro VI puts the floor at 95% because higher than that is not realistic under all operating conditions.
machin
162
I've just been looking through the results, and I believe I'm correct in saying that all three manufacturers were doing 13 lap stints the majority of the time. (it was difficult to follow this in the race because the cars quite quickly got out of sync due to various incidents).
Under these circumstances we can construct another chart showing how much kinetic energy each manufacturer had (on average) over those laps where the limit is the lower value of (fuel capacity/no. of laps + Hybrid allowance per lap) or (ACO fuel limit per lap + Hybrid allowance). It turns out that at 13 lap stints, all cars were limited by the ACO per lap limit, and none of the cars were limited by the fuel tank capacity.
So, due to the EoT Audi had a 0.2MJ per lap advantage over Porsche and Toyota, and no difference in stint length. Given that the cars were doing average lap times in the 205 second area, and assuming the car is accelerating (or at WOT) for 80% of that time (164 seconds), that is an average of 1.21 kJ/second, or 1.62 bhp advantage to Audi.
What is slightly surprising is that, according to the EoT tables, Porsche and Toyota, should have been capable of doing 14 lap stints without any fuel saving, or maybe 15 with a little bit of fuel saving..... and yet it appears they weren't.....
langwadt
MJ/kg for LPG is slightly higher or the same as petrol ~45Mj/Kg, but it is lighter so less Mj/L, ~27 vs. ~35 Mj/L
Post Reply
