production engines
roninho
roninho
production engines
Hi there,
in recent years quite some racing series have started using engines based on production engines. So modified production engines.
Now i have read that the Lamborghini GT3 engine is exactly the same as the production car engine. I have also heard that a Ferrari 458 with a production engine won the bathurst 12 hours.
Do you have more examples of engines straight from the production car that are used in racing series? So without any modifications?
roninho
roninho
Re: production engines
So nobody got a clue?
matt21
86
roninho wrote:So nobody got a clue?
Mercedes SLS GT3
Porsche GT3
Corvette GT3
Basically all GT3 are more-or-less standard equipment.
Some of them are also de-tunded due to the size of the restrictor given bei BoP.
tuj
tuj
I guess I'm wondering what you call a 'production' engine? Production architecture? If so, then most of the SCCA national championships have been won with highly blueprinted and optimized 'production' engines. Spec Miata is a series where generally speaking, true production engines are used, nearly as they come from the factory.
J.A.W.
J.A.W.
109
& many racing classes specifically forbid 'production' mills, but Moto 2/WSBK are top-flite exceptions..
roninho
roninho
tuj wrote:I guess I'm wondering what you call a 'production' engine? Production architecture? If so, then most of the SCCA national championships have been won with highly blueprinted and optimized 'production' engines. Spec Miata is a series where generally speaking, true production engines are used, nearly as they come from the factory.
What i mean with a production engine is the engine that is taken from a car allowed to drive on public streets and is not modified for racing (or very limited modified for racing).
So for example engines from one of these cars: http://autoweek.com/article/car-news/500-hp-club
I Always figured that the engines one can drive on the public roads are not suitable for racing, but as i said in my initial post i am now aware of at least 2 unmodified engines that have been used in racing.
I guess i'm wondering if i pick an engine from one of the cars as listed above and put it in a formula-chassis and only allow some minor modifications for reliability, would it last for 2+ hours/500 miles racing?
roninho
roninho
Mercedes SLS GT3
Porsche GT3
Corvette GT3
Thank you.
Question is what is ''more-or-less standard''?
J.A.W.
J.A.W.
109
As purchased from the showroom, but raced with a track specific set-up including extra aero/ride height mods & etc..
andylaurence
123
Completely standard engine from a Ford Fiesta ST. It even uses the standard intercooler. It's de-tuned from standard and practically lasts forever.
J.A.W.
J.A.W.
109
So A-L, which tuning parameters are derated from showroom standard - for the F-racer application?
matt21
86
roninho wrote:
Mercedes SLS GT3
Porsche GT3
Corvette GT3
Thank you.
Adaption to air-restrictors, different catalysts, changed ECU, different intercoolers, exhaust, coolers
, dry sump etc.
The rules say:
- [Car] to be equipped with an engine used in a production car and made in a quantity of at least 300 units.
andylaurence
123
Physically, it's identical aside from the air box and exhaust. It runs a life ECU and the map on that is restricted to about 170bhp. I don't know how as that's ford IP. Presumably boost is restricted.
J.A.W.
J.A.W.
109
Ok, thanks A-L, does it also have a ECU fixed rev-limiter?
I ask since derestricting inlet/exhaust often allows more, rather than less - boost..
andylaurence
123
It's not the rev limiter that restricts performance. It's the map. I believe it's done with reduced boost pressure as you can see the ECU trying to manage the boost pressure on each gear change.
