Driver adjusted differentials are out
Post Reply
hardingfv32
32
The FIA is prohibiting drive adjustable differentials this weekend.
What might be the connection between this and the new restrictions concerning off throttle mapping?
Brian
DaveW
239
Re: Driver adjusted differentials are out
hardingfv32 wrote:The FIA is prohibiting drive adjustable differentials this weekend.
Brian
Not much, I would think. A reference to your source would be appreciated.
hardingfv32
32
The GP practice telecast.
Brian
Jersey Tom
Driver adjustable diffs are actually one of my favorite bits of tech on F1 cars. Pretty crappy if they do ban them.
Pierce89
Jersey Tom wrote:Driver adjustable diffs are actually one of my favorite bits of tech on F1 cars. Pretty crappy if they do ban them.
seriously!? As long as they've been around, it would make no sense. they've had them forever, so I don't see much scope for cost savings. They are also extremely cool.
hardingfv32
32
1) What aspects of their use or design do you find interesting?
2) I think this ban has something to do with off throttle mapping and not cost reduction. No cost to be saved by restricting the driver's ability to adjust them. The diff's design is not going to change one way or the other.
Brian
Jersey Tom
I find ramp and clutch diffs in themselves to be very interesting, with the ability to significantly impact the handling of the car by varying the amount of differential locking on-throttle, off-throttle, and neutral throttle.
Being able to adjust those parameters on the fly with an E-diff is bad ass.
hardingfv32
32
I believe that each map of a F1 diff must mimic a mechanical unit. So, a selected diff map must control on-throttle, off-throttle, and neutral throttle with a fixed relationship similar to that of a mechanical system. In the case of a diff with ramps, you can not vary the ramp angle within one map setting. Of coarse this quasi mechanical diff is replicated by means of a electronic/hydraulic system.
Is this how you understand their use?
Brian
Jersey Tom
Correct, that is my understanding.
Post Reply
