Jersey Tom wrote:However, these are only valid for cars that behave similar to a bicycle model. If you were to extrapolate a 4-corner model and add toe to the front or rear axles, since you're still within the linear range of the tires there's no really no change to the yaw response of the tires. Despite this, we know that it DOES have an effect. Incidentally, since these bicycle model derivatives are a function of CS only, there would be no predicted change in response if you were to add a huge front bar, etc. So what are we missing?
Load transfer is the key, and cannot be neglected. The argument, "well the slip angles and forces and load transfer are small" does not mean that they can be forgotten. It's the rate of change that's important, rather than the absolute value. When you add toe out to the front end, there's an introduction of vertical load transfer sensitivity, in addition to just yaw sensitivity. The result is that you have a self-REDUCTION of into-corner yaw moment, with front toe out and with load transfer in the appropriate direction. This REDUCTION of yaw moment is key, and lets the car reach a steady state condition quicker, with less lag, albeit at a smaller steady state value (of course this can be changed by just adding more steering input to begin with). Similarly, as you increase understeer you will also make response faster.
thisisatest wrote:also, as often is said that toe out helps with turn in, it is also said that too much toe out can lead to understeer. i think this is part of the picture. if the end result is some understeer, then the transient turn in behavior will feel more aggressive.
Users browsing this forum: MOWOG, sink, vikram_d and 11 guests
