Monster Energy Racing - MER-VW1[Model] Launched
Post Wed May 16, 2012 11:09 pm
Here is my latest Rear Wing, and my latest attempt on sidepods. The render makes both look bad however in actuality they are fairly decent. :D =D> :lol: 8) :wink:
Monster_Energy_F1
Post Thu May 17, 2012 6:49 am
would you be able to give us a shot of the front because the side pods look really small at the front which would greatly affect the amount of air going into them, causing overheating
Aussie
Post Thu May 17, 2012 4:17 pm
Sure, one second. :lol:
Monster_Energy_F1
Post Sat May 26, 2012 7:33 pm
A few updates; finally. New Sidepods (Again), and an Engine cover. Will attempt to incorporate Wesley's and JordanGP's airbox idea into my car.
Monster_Energy_F1
Post Sun May 27, 2012 8:06 am
The sidepod intake area is really chunky while the intakes themselves are quite small. There's a large vertical face for air to get all draggy on, is there some components hiding in there or is that just how it turned out? The older sidepods (the front half at least) look better to me. Good move with the proposed engine cover.
I've found a way of ducting exhaust right to the diffuser edge like in 2011 and created a new wheel fastener that could allow sub 2 second pitstops see them here --> My 2013 F1 Concept Project
MIKEY_!
Post Sun May 27, 2012 10:37 am
Your head protection and beamwing is illegal
Thanks
Nick
Budding F1 Engineer
N12ck
Post Sun May 27, 2012 10:46 am
To be honest the proposed Airbox was way too hard, so i've gone with the conventional airbox. The car is nearly done; Front Wing, Diffuser and Suspension left. And of course the detailing. Here it is so far:
And Nick, why are they?
Monster_Energy_F1
Post Sun May 27, 2012 10:47 am
Beamwing is too high, and the headprotection doesnt slop upwards at the correct angle or enough, look at the 2012 regs and scroll all the way to the bottom few pages and it shows dimensions of the headprotection and you will see what I mean :D
what height is your chassis?
Nick
Budding F1 Engineer
N12ck
Post Sun May 27, 2012 10:49 am
Yes. I followed the dimensions correctly, but then I thought I might edit it. And the Beam Wing looks fine, let me test it and i'll get back to you. What do you think of the car as a whole?
Monster_Energy_F1
Post Sun May 27, 2012 10:56 am
Monster_Energy_F1 wrote:Yes. I followed the dimensions correctly, but then I thought I might edit it. And the Beam Wing looks fine, let me test it and i'll get back to you. What do you think of the car as a whole?
the head protection is illegal, I can tell by looking at it, and what height is your tub? it is good, but i don't understand what your trying to do with the V-nose extending all the way to the tip of the nose (unless your trying to stop overspill, but then you gain drag elsewhere), another thing, the front of your floor is illegal (not allowed to see bodywork from below) (you can see the sidepod from underneath), I would make the sidepod intakes larger, other than the illegalities, it looks fine, although I would extend your engine cover to the max triangular area, as this reduces the 'flapping around' and also helps condition the air for longer.
Nick
Budding F1 Engineer
N12ck
Post Sun May 27, 2012 10:57 am
Thanks Nick,
You were correct on the beam wing. Mistake has been rectified. :D
Monster_Energy_F1
Post Sun May 27, 2012 11:00 am
Monster_Energy_F1 wrote:Thanks Nick,
you need to sort the headprotection, I will show a side comparison
Well done
Nick
Budding F1 Engineer
N12ck
Post Sun May 27, 2012 11:02 am
The v-nose is pretty much fine I reckon, I just cba to make a new one atm.
I'm happy with the engine cover for now.
The Headrest will be fixed in a minute.
EDIT: Hopefully FS will allow the headrest as it is.
Monster_Energy_F1
Post Sun May 27, 2012 11:14 am
Monster_Energy_F1 wrote:The v-nose is pretty much fine I reckon, I just cba to make a new one atm.
Hopefully, but if you want to get faster, do all these things it all helps :)
Budding F1 Engineer
N12ck
Post Sun May 27, 2012 11:19 am
I told you about that beam wing a month ago...
Don't just design things randomly, make sure they are legal, and in the fight position first.
jordangp
PreviousNext
Return to Engineering projects
Who is online
Users browsing this forum: No registered users and 1 guest
